couple of quick hondata questions
as of recent i have had a hondata s200 with a P28 ecu installed and tuned in my 00 type R.
question #1:
after filling up the car does not want to start and it idles at about 200-500 RPM. i called my tuner (locash racing) and he said that there was a relief/purge valve i needed to disconnect. and it was on the intake manifold around the throttle cable. i have tried to disconnect the vacum line from the FPR and the sensor next to it. and with no luck, it still happens.
can anyone please provide some insight to this, IE a picture or the name of the line to unplug? Please
question #2: (easy)
if i install a voltage stabilizer will this affect the tune?
thank you in advance
question #1:
question #2: (easy)
its on the firewall correct? ill do that and add some fuel. should i plug the open end?
thank you for your help
BTW, hondata is the best thing ive done for my car. if anyone is thinking of upgrading this is the thing to do. also locash racing is were its at
/rant
/rant
spoonhbk11
Engine Management and Tuning
Dec 8, 2017 07:12 PM
