No Spark on CRX Si
Old Mar 7, 2008 | 12:05 PM
crxricer66's Avatar
Default free h22 motor.....need help
now that you looked....theres no motor. my buddies crx has no spark. has new ecu,and new distributor. there is no spark what could it be?? car is a 91 crx si
Old Mar 7, 2008 | 12:11 PM
Notorious RYAN's Avatar
Default Re: free h22 motor.....need help (crxricer66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">now that you looked....theres no motor. my buddies crx has no spark. has new ecu,and new distributor. there is no spark what could it be?? car is a 91 crx si</TD></TR></TABLE>
Take the cap off the dizzy, and turn the roater 15 degrees. it should spark
Old Mar 7, 2008 | 12:16 PM
crxricer66's Avatar
Default Re: free h22 motor.....need help (Notorious RYAN)
the car died while he was driving.... we replaced the ecu with a known working one and also a new dizzy. would the main relay make it not spark??
Old Mar 7, 2008 | 12:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">the car died while he was driving.... we replaced the ecu with a known working one and also a new dizzy. would the main relay make it not spark??</TD></TR></TABLE>
yeah, go cheep first, and replace that main relay to see what happenes
if not, check grounds, if its not a good ground. your valve cover.
and check if theres any loose connections on your ecu
Old Mar 7, 2008 | 01:07 PM
crxricer66's Avatar
he lives about 500 miles away so.... will the main relay cause no spark tho?? i know it controls the fuel pump..... all connections seem good, ill have him check the valve cover ground, he did clean the thermostat ground cuz i know thats for the ecu..... any suggestions are appreciated.
Old Mar 7, 2008 | 01:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">he lives about 500 miles away so.... will the main relay cause no spark tho?? i know it controls the fuel pump..... all connections seem good, ill have him check the valve cover ground, he did clean the thermostat ground cuz i know thats for the ecu..... any suggestions are appreciated.</TD></TR></TABLE>
The relay, could have a bad connection. check fuses.
here is a good way to check for spark. be careful.
take the spark plug out of cylineder 1. and put the plug wire on the spark plug.
and hold the wire with your hands, and rest the threds of the plug on the the edge of the valve cover. and have someone try to start the car, and if it is, throughing sparks. you will be able to clearly see them.
Old Mar 7, 2008 | 01:41 PM
YLWCRX's Avatar
It could be a bounch of different things that could make the car not run. Do a search and you will be suprised at how much info. can be found.
Things to check:
Ignition switch
Timing Belt
Main relay (Controls main ignition and fuel pump)
Among other things. You need to provide more info if you want a better answer.
Old Mar 7, 2008 | 01:57 PM
crxricer66's Avatar
Default Re: (YLWCRX)
i have been searching and it says ecu, distributor and they are both out. we know it has no spark by the way.... k ill have him check them things. thx guys
Old Mar 7, 2008 | 02:23 PM
Default Re: (crxricer66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">i have been searching and it says ecu, distributor and they are both out. we know it has no spark by the way.... k ill have him check them things. thx guys</TD></TR></TABLE>
check and see if the ecu is throwing codes. if so. lookem up boi
Old Mar 7, 2008 | 03:43 PM
wood 1's Avatar
see if fuse 14 is blown
Old Mar 7, 2008 | 04:13 PM
crxricer66's Avatar
Default Re: (wood 1)
he said he checked all fuses and i asked him many times to make sure thx tho
Old Mar 7, 2008 | 04:53 PM
crxricer66's Avatar
got it, it was the main realy thx guys
Old Mar 7, 2008 | 06:09 PM
kalm_traveler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">got it, it was the main realy thx guys</TD></TR></TABLE>
So just fixing the main relay got your spark back? I'm workin on this 4-door right now that's givin me a no-spark problem too but having a pickle trying to diagnose the bad part/connection...
Old Mar 9, 2008 | 03:39 AM
Yup! FTW!
thunderlips
Apr 20, 2008 12:09 PM
coldpimpin
Apr 10, 2007 08:41 PM
snapso_24
Jul 5, 2005 03:26 PM
HyShiftRacer
Apr 22, 2005 01:09 AM
2point6
Jul 14, 2003 12:02 PM
