Benen Industries Rear lower tie bar
Old Mar 7, 2008 | 10:31 AM
Morty's Avatar
Default Benen Industries Rear lower tie bar
hey guys just seeing if any of you know if the benen rear lower tie bars will fit our cars? it specifys94-01 integra but i thought the type r's were different?
dont want to buy something, and it not fit
thanks in advance, deryk.
Old Mar 7, 2008 | 10:41 AM
Jpres927's Avatar
Default Re: Benen Industries Rear lower tie bar (Morty)
not gonna fit correctly on a ITR
Old Mar 7, 2008 | 10:48 AM
white rocket's Avatar
I don't see why it wouldn't fit. The distance between the control arm bolts on the subframe should be the same on any DC2/4. I could be wrong though.
Old Mar 7, 2008 | 12:47 PM
Justin3's Avatar
Default Re: (white rocket)
It will not fit the subframes are different on a Type-R. You can make it fit with a little massaging from a grinding wheel though. It's very minimal the amount that has to come off of corners of the tie bar.
Old Mar 7, 2008 | 01:41 PM
Jpres927's Avatar
Default Re: (Justin3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin3 &raquo;</TD></TR><TR><TD CLASS="quote">It will not fit the subframes are different on a Type-R. You can make it fit with a little massaging from a grinding wheel though. It's very minimal the amount that has to come off of corners of the tie bar.</TD></TR></TABLE>
yuup maybe like a 1/4 off each side
Old Mar 7, 2008 | 01:52 PM
Jackson's Avatar
I test fit one on my ITR for the JHP site. They bolt up just fine but the ABS lines get in the way and have to be unbolted. (I didn't keep it on the car)
Old Mar 7, 2008 | 02:26 PM
94rs-turbo's Avatar
Get the Beaks bar fits itr perfectly buddy had it on his
Old Mar 7, 2008 | 04:18 PM
tegdude227's Avatar
i have polished one on teg its not a Type-r but i had to do work with the abs lines and stuff buddy has the beaks and it fit great
Old Mar 7, 2008 | 05:56 PM
JjuuN R's Avatar
Default Re: Benen Industries Rear lower tie bar (Jpres927)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jpres927 &raquo;</TD></TR><TR><TD CLASS="quote">not gonna fit correctly on a ITR</TD></TR></TABLE>
Know WTF you're talking about before you **** out wrong information straight out of your asses please.
OP, it fits perfectly fine, just need longer LCA bolts is ALL, not a F'ing grinder...
Old Mar 7, 2008 | 08:41 PM
Morty's Avatar
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Get the Beaks bar fits itr perfectly buddy had it on his</TD></TR></TABLE>
A bit harder to find Beaks up in vancouver...it seems anyways.
i wanted one of those from the start but was told it doesnt fit...but if it does ill go that route, thanks
Old Mar 7, 2008 | 08:43 PM
Morty's Avatar
Default Re: Benen Industries Rear lower tie bar (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
OP, it fits perfectly fine, just need longer LCA bolts is ALL, not a F'ing grinder...</TD></TR></TABLE>
thanks cory for clearing it up...everyother person was saying the opposite...
do you or anyone else know if i will need longer bolts for the Beaks Bar as well?
thanks again, deryk.
Old Mar 7, 2008 | 09:47 PM
00-501itrspec's Avatar
haha tell em
Old Mar 7, 2008 | 10:58 PM
Jpres927's Avatar
haha damm chill dude its not that serious, but yeah i dont know how the new benen **** is but when I bought my benen rear tie bar a couple years ago it came with longer bolts.
Old Mar 8, 2008 | 05:32 AM
JjuuN R's Avatar
The factory rear LCA bolts will work for the Beaks bar, but you need ones with about 3-4 more threads with the Benen.
Old Mar 8, 2008 | 08:53 AM
Morty's Avatar
thanks again guys
SilverDC4
Sep 29, 2005 10:56 AM
DeDonDeRosa
Jun 7, 2005 10:26 AM
.Ryan
Mar 19, 2003 02:24 PM
