Rim and tire question...lowered with 15's ok?
Old Mar 7, 2008 | 09:12 AM
benclimber17's Avatar
Default Rim and tire question...lowered with 15's ok?
I'm looking to put some konig's or some drag's on my 99 ex. It's lowered almost 2.5 inches. I have some 17" racing harts right now, but I'm thinking about going to some 15's for a more jdm look. What I'm really concerned with is the tire size and sidewall ratio...I was thinking 205/50/15 but I don't know if I'll run into rubbing issues. Should I find some lower profiles like 45's? I'm not too keen on 195's if they'll look all wierd...let me know...I will probably be ordering tonight...
Modified by benclimber17 at 1:40 PM 3/7/2008
Old Mar 7, 2008 | 09:16 AM
shadohconspiracy's Avatar
whats the wheel width you are trying to run?
195 should look pretty beefy on your average 6.5inch wide wheels. you shouldnt expereience rubbing issues with taht drop and those tires.
theres also other things to consider like spring rates and stuff
Old Mar 7, 2008 | 09:20 AM
H22Ej1's Avatar
Shenanigans
Default Re: Rim and tire question...lowered with 15's ok? (benclimber17)
if you want your tire size to stay close to stock so your spedo wont be way off and you wont rub get a 195/50r15. the 205/50r15 would also be a good choice, however the diameter is larger and your speedo will be off more and there will be more of a chance for rubbing. if your getting a 6.5 inch whell 195 will be perfect, a 7 inch wide i would go 205, before you get ny of this also consider what tires companies offer in these sizes bc if your concerened about traction its not always true that a wider tire offers better traction
Old Mar 7, 2008 | 09:50 AM
Richard...'s Avatar
Default Re: Rim and tire question...lowered with 15's ok? (H22Ej1)
http://www.miata.net/garage/tirecalcold.html
should give you an idea of were your at!
chrisc543
Apr 16, 2014 11:33 AM
jdmsir4dr
Apr 11, 2012 05:21 AM
DuVaL rAcEr
Apr 20, 2006 12:32 PM
JDM-EJ1
10
Jun 19, 2005 12:43 PM
Indiana Jones
Jun 3, 2005 10:46 AM
