Need technical info (Sensor Readings)
Old Mar 7, 2008 | 08:52 AM
jardolei's Avatar
Default Need technical info (Sensor Readings)
Hi guys, I'm in the process of doing maintenence on my 97 5th Gen and some things are bothering me. recently I feel that my lude is not giving me all the performance its supposed to. Here are the facts:
97 Lude 180k KM (about 130k miles)
Completely stock except for intake
Changed:
Plugs a couple of months ago (they are clean)
Battery
TPS (TPS readings perfect, 10% on idle)
Rotor and Cap + Wires
Tested engine compression:
215-212-200-210
I consider this VERY good for 130k miles on it
On the scanner I'm getting 1.25v for the #1 O2 sensor contstant (idle). It will sometime change when WOT. Is the constant 1.25v normal?
2nd O2 sensor gives (on idle) 1-1.1v
We tested while driving and in 3rd doing 35-40mph (60km/h) the scanner says 30% engine load. That normal?
The only thing i can see is exhaust or headers? I still have the original ones (as far as i can see since I bought the car 2 years ago) Of course theres rust and exhaust pretty used. The exhaust still seems to travel though it "normally". Cant see headers because I syill have Heat shield on.
Any Ideas?
Old Mar 7, 2008 | 08:59 AM
98vtec's Avatar
moderator emeritus
Default Re: Need technical info (jardolei)
Old Mar 7, 2008 | 09:13 AM
jardolei's Avatar
Default Re: Need technical info (98vtec)
Ok, Thanks a lot for the graph. As I can see I should be getting about .5v for both O2 sensors? How is it possible to get 1.25! I have no check engine at all...
Sorry for all the questions but i'm not THAT technical, learning though the process though....
Old Mar 8, 2008 | 08:43 AM
jardolei's Avatar
Bump, anyone else?
Old Mar 10, 2008 | 08:58 AM
jardolei's Avatar
Can someone tell me what the voltage of O2 Sensor #1 should have at idle when cold? hot?
Thanks
fishin715
Dec 1, 2015 02:21 AM
arielb1
Feb 24, 2006 08:31 AM
GSlowR
Mar 23, 2005 01:36 PM
95civiccoupe31
Jul 2, 2002 03:39 PM
