I need help getting to my eg gauge cluster!!!
Old Mar 7, 2008 | 08:01 AM
JunkyardAccord's Avatar
Default I need help getting to my eg gauge cluster!!!
How Do I remove this?!?! (Already removed 2 screws above cluster)
Old Mar 7, 2008 | 08:06 AM
crazyguy's Avatar
Default Re: I need help getting to my eg gauge cluster!!! (JunkyardAccord)
carefully pry and remove the hazard light switch and u will see a screw and remove it and 2 screw to remove from upper cluster bazel area
Old Mar 7, 2008 | 08:18 AM
Default Re: I need help getting to my eg gauge cluster!!! (crazyguy)
still not commin out and i cant get the effin clock to come out either..
Old Mar 7, 2008 | 08:23 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardAccord &raquo;</TD></TR><TR><TD CLASS="quote">still not commin out and i cant get the effin clock to come out either.. </TD></TR></TABLE>
i remember the clock stays when i pulled the bazel off. i didnt even need to remove the clock.
Old Mar 7, 2008 | 08:28 AM
well it still feels like its connected to something do i have to pull it from a certain angle? it kind of feels like its stuck from the vents or something..
Old Mar 7, 2008 | 08:29 AM
crazyguy's Avatar
m...check if there is a screw at the center vent area, i didnt remember about this one cause it was 2 years ago when i pulled the bazel..and it should pull right off..
Old Mar 7, 2008 | 08:36 AM
obd-0-4life's Avatar
remove the switch under the clock and there is a screw there.
Old Mar 7, 2008 | 08:38 AM
EcivicG's Avatar
i didn't have to remeove my hazard switch.
i just removed the 2 screws above the cluster, then took a flathead and carefully pryed at the end where the two heater vents are first and moved to the left.
there are fins or something that hold the trim to the dash.
just be careful
Old Mar 7, 2008 | 08:39 AM
Your Name's Avatar
Default Re: I need help getting to my eg gauge cluster!!! (obd-0-4life)
dont break it.. it will come out clean take your time
Old Mar 7, 2008 | 08:50 AM
instrument's Avatar
its always hard to get it out the first time.
the vents are really snug, its easiest to use a screw driver and slowly pry it out.
if its going to break, it will break on the far left side near the vent.
Old Mar 7, 2008 | 09:02 AM
saywhat's Avatar
Default Re: (instrument)
I am pretty sure these are impossible to remove without screwing up one of those metal tension tab things... But even broken it still reinstalls fine.
Old Mar 7, 2008 | 09:07 AM
H22Ej1's Avatar
Shenanigans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EcivicG &raquo;</TD></TR><TR><TD CLASS="quote">i didn't have to remeove my hazard switch.
just be careful</TD></TR></TABLE>
also false there is a screw under the hazzard switch
i just removed mine last week, once you get those 3 screws out be very careful to pry it off and not break it...i started from the right side and worked to the left. the bottom of the cluster cutout has clips that slide into the dash so be careful not to break those. just take ur time itll come out easy.
there is a write up that bauley civic did about changing ur cluster and climate control bulbs and it tells you how to remove that...give me a sec ill look for it
edit: https://honda-tech.com/zerothread?id=661308
Modified by H22Ej1 at 5:18 PM 3/7/2008
Old Mar 7, 2008 | 09:13 AM
twentytwocpb's Avatar
Default Re: I need help getting to my eg gauge cluster!!! (H22Ej1)
try picking it up a little from the bottom. Beware...becuz it has clips!
Old Mar 7, 2008 | 09:30 AM
EcivicG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">
false its under the hazzard swich
edit: https://honda-tech.com/zerothread?id=661308</TD></TR></TABLE>
im sure your right, but the guy who owned my car before me must have just not put the screw back into place.
my fault for misinformation
Old Mar 7, 2008 | 09:35 AM
Default Re: I need help getting to my eg gauge cluster!!! (EcivicG)
I just put grill mesh between my clusterfck and my dash trim!!!
not very jdm lookin but looks sweet!!!
Old Mar 7, 2008 | 10:51 AM
BlueIntegraBoy's Avatar
Uhh, he is correct. He said the screw is behind the [hazard] switch under (below) the clock.
Old Mar 7, 2008 | 02:18 PM
H22Ej1's Avatar
Shenanigans
Default Re: I need help getting to my eg gauge cluster!!! (BlueIntegraBoy)
my bad i read that completely wrong
joshmarlette
Oct 8, 2004 06:25 PM
celph.
Nov 21, 2003 10:21 PM
Evs-One
10
Jan 4, 2003 06:57 PM
Mikeveli
May 29, 2002 01:33 PM
karmannghia
Nov 7, 2001 06:16 AM
