is this block trash?
Old Mar 7, 2008 | 03:59 AM
kirbyman's Avatar
Default is this block trash?
hey guys, was test fitting my new engine today when i noticed that where the mount bolts to the block is cracked, and been stripped out, heli-coiled, and those have been stripped out. let me know what you guys think.
if it is a waste, and i need a new one, will all the stuff from it bolt to a b16? or another b series? cause i know gsr motors are hard to find..
Old Mar 7, 2008 | 04:56 AM
Lubo_25's Avatar
Default Re: is this block trash? (kirbyman)
it's not trash but will require larger tapped holes, the cracked side looks to be able to accept a bit of welding for tapping to a larger hole as well...your engine mount might require some larger clearance holes double check all of that...
Old Mar 7, 2008 | 07:40 AM
kirbyman's Avatar
Default Re: is this block trash? (Lubo_25)
i think im just gonna bring the motor back to where i got it and go buy a crx locally.. i don't really have the money to be spending on this right now..
Old Mar 7, 2008 | 07:51 AM
Lubo_25's Avatar
very well then glad to have offered some help take care comrade
Old Mar 7, 2008 | 09:16 AM
Chris Tune's Avatar
you can fix that with around 40 bucks...
Old Mar 8, 2008 | 03:31 PM
kirbyman's Avatar
Default Re: is this block trash? (Chris Tune)
thanks Lubo_25, i think thats what i would do if i had more money, but my budget ran out..
Old Mar 8, 2008 | 03:38 PM
mar778c's Avatar
Community Builder
Community Influencer
Yes, it can be fixed without a lot of expense.
Old Mar 8, 2008 | 04:21 PM
4g hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">you can fix that with around 40 bucks... </TD></TR></TABLE>
timeserts+weld=fixed
Old Mar 8, 2008 | 10:17 PM
dthug's Avatar
Default Re: is this block trash? (4g hatch)
i would never mess with a block that has any problems like this. ruins the intergrity of the block. just my opinion. i seen to many bad things happen with that particular mount
Old Mar 9, 2008 | 12:16 AM
Fat Chick Magnet's Avatar
JB WELD!
Old Mar 10, 2008 | 07:16 AM
kirbyman's Avatar
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">i would never mess with a block that has any problems like this. ruins the intergrity of the block. just my opinion. i seen to many bad things happen with that particular mount</TD></TR></TABLE>
i believe it happened when the car was wrecked.. it was hit behind the pass. side axle, but im pretty sure the frame warped, and tore this mount apart... i wouldn't want to disrupt the integrity of it, either... not pushing the power that motor has in it..
Old Mar 11, 2008 | 01:43 PM
matt94z's Avatar
wow that looks familiar!! This is from hitting a gaurd rail head on at about 25mph...
I was going to have it welded, but they told me I would have to strip the block completely down, cause when you weld aluminum it will get soo hot all the seals and plastic will melt.... So I said F it and got another bare B16 block for $50.
theres only 1.5 miles on this motor, this happened on the test run.. hit a patch of ice and that was the end...
Old Mar 11, 2008 | 03:52 PM
dinko's Avatar
Default Re: is this block trash? (matt94z)
hammer time
Old Mar 12, 2008 | 03:43 PM
kirbyman's Avatar
Default Re: is this block trash? (dinko)
ouch.... that sucks, man...
Old Mar 12, 2008 | 05:05 PM
VtecKiDD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">
timeserts+weld=fixed</TD></TR></TABLE>
cmamtower
Oct 23, 2010 08:53 AM
DCTegg
Aug 23, 2009 12:00 PM
teamitr
Nov 17, 2005 07:09 PM
al3e
Jun 5, 2005 09:13 AM
gsrcivic619
Apr 8, 2004 05:30 AM
