auto to manual swap EK pedal assembly on a EG?
can i use a 96 civic clutch pedal and brake pedal assembly on my EG......i'm not going to use the slave cylinder or lines leading from the master cylinder (can't not even the same series or realted series motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS2 FAB »</TD></TR><TR><TD CLASS="quote">wow 4th page already..........has'nt even been 30 mins! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS2 FAB »</TD></TR><TR><TD CLASS="quote">so nobody knows this? </TD></TR></TABLE>
They work. There is no difference. 92-00 civics, 94-00 integras have the same pedal assembly. You could use either.
I think you could get away with using the ek clutch line aswell. it cuts through over the transmission instead of going around the whole engine bay like the eg clutchline.
Right now im doing and auto conversion car on my car, im using half the ek lutch line and half the eg line.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops »</TD></TR><TR><TD CLASS="quote">you already have it? just try it.</TD></TR></TABLE>
no sir, and i wasn't about to run out and spend $100 on argon, to modify my $30 pedal assembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">They work. There is no difference. 92-00 civics, 94-00 integras have the same pedal assembly. You could use either.
Right now im doing and auto conversion car on my car, im using half the ek lutch line and half the eg line. Good luck.</TD></TR></TABLE>
thank you kind sir......
i think ill just use a -AN fitting and braided line or just be lazy and use hybrid racings line
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1024818
That was hard...</TD></TR></TABLE>
for someone honoring earl laskey you clearly did not adopt his attitude
LongBeachEP3
Aug 2, 2007 01:17 AM
