looking to run methonal
1600 or 1000cc injectors. which ones should i get it is an all motor h22 set up. also the head was done by port flow will it need to be sent back and reworked if i do run the methonal
Take whatever injector size you would use if you were running gasoline and double it. That should get you enough injector and you will probably have some to spare.
You might as well go 1600's. 1000's would probably be ok, but 1600's are usually cheaper, and will be no problem to tune on Meth like they can be on gas.
B16A1-EF9
Jun 24, 2004 03:32 AM
Quad-Damag
Sep 7, 2003 11:02 AM
