tein ss coilovers
Old Mar 6, 2008 | 06:42 PM
preludepower01's Avatar
Default tein ss coilovers
i am about to install so tein ss coilovers on a 01 honda prelude and i wanted to know if i drop it 2in to 2.5in all around will i need to get a camber kit
Thanks
Old Mar 6, 2008 | 11:56 PM
FFXSi4WS's Avatar
Most definitely unless you are fond of excess negative camber devouring your tires on a bi-monthly basis, and check into the Adjustable Upper Control Arm thread :D
Old Mar 7, 2008 | 02:23 AM
Mykizism's Avatar
Default Re: (FFXSi4WS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFXSi4WS &raquo;</TD></TR><TR><TD CLASS="quote">Most definitely unless you are fond of excess negative camber devouring your tires on a bi-monthly basis, and check into the Adjustable Upper Control Arm thread :D</TD></TR></TABLE>
the majority of tire wear is due to improper toe in/out, and caster.. though caster is not adjustable on most hondas it will be the latter..
camber has little effect on tire wear if toe is corrected after coilover install
01bb6boy
Jul 9, 2011 07:11 PM
PrittyPearllude
Suspension & Brakes
Apr 11, 2006 06:50 PM
VtecBlissS2k
Honda S2000
24
Feb 17, 2005 06:25 AM
Halo
Suspension & Brakes
Jan 7, 2005 01:09 PM
billyzakkus
Nov 28, 2003 12:07 PM
