closed deck h22-what is safe?(boost)
Old Mar 6, 2008 | 04:35 PM
nello a.'s Avatar
Default closed deck h22-what is safe?(boost)
i dont ever come in here. i figured this would be the place to ask.
stock bottom and top, plenty of fuel and a good tune.
what can it hold safely?
Old Mar 6, 2008 | 04:39 PM
BOMBCRU's Avatar
Safe is 6-7 psi small turbo
Sleaves are to weak, h22's are notorious for spinning bearings to.
I have hear of them getting 17 psi but on a damn good tune and never ever see's boost. I would strongly suggest saving up and gettign it sleeved or go to for sale forum and getting golden eagles $950 special
Old Mar 6, 2008 | 04:43 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (BOMBCRU)
special is actually $875
Old Mar 6, 2008 | 04:57 PM
JDM90CB7's Avatar
the h22 sleeves are actually very strong, the ring lands on the pistons usually give out first. Mahle gold series pistons have been know to work really well with the stock sleeves, they've seen up to 20psi safely with a good tune. I ran 10psi on my stock h22 with no problem, daily driven in fact. if you have a really good tune with no knock you should be ok to run up to 10psi maybe even 12psi. if your going all out, get it sleeved, if your on a budge, try the mahle pistons, alot cheaper than sleeving.
Old Mar 6, 2008 | 05:00 PM
TopNotchPerformance's Avatar
Default Re: (JDM90CB7)
H22 = best kept N/A
no problems and nice DD
Old Mar 6, 2008 | 05:03 PM
speedworks's Avatar
Default Re: (TopNotchPerformance)
bearings are not the problem, pistons are the problem.
Old Mar 6, 2008 | 05:14 PM
JDM90CB7's Avatar
Default Re: (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">bearings are not the problem, pistons are the problem. </TD></TR></TABLE>
how much hp did you make on 19psi to run a 10.8??^^^
Old Mar 6, 2008 | 05:50 PM
TheWickedOne's Avatar
lets not forget about the rods.... they scare me just looking at them..
Old Mar 7, 2008 | 08:00 PM
meanEG's Avatar
i blew stock pistons at 10psi ona gt30, probably about 350 whp or so. it lasted a few weeks.
jaykdc5
Sep 2, 2011 11:50 AM
mighty137
Jun 7, 2008 10:16 AM
ilikehonda
Jan 11, 2006 05:45 PM
tunedbylorange.com
Jan 14, 2004 11:33 AM
tunedbylorange.com
Dec 4, 2003 03:56 PM
