99 civic rear wheel bearing replacement help need (drum brakes)
Old Mar 6, 2008 | 03:21 PM
ooopseyesharted's Avatar
Default 99 civic rear wheel bearing replacement help need (drum brakes)
My fiancee has a 99 civic 4 dr. The rear wheel bearings need replaced. They are howling real bad. The car has drum brakes. I just need to know how to do it and if there are any honda specific tools required. Thanks guys.
Old Mar 6, 2008 | 04:51 PM
SpoolinB16A's Avatar
Ok first remove the front drum, remove the rear brakes then there should be a 32mm nut i believe you'll need a breaker bar remove the nut then it should just pop out.
Old Mar 6, 2008 | 07:00 PM
Default Re: (SpoolinB16A)
i was really hoping that i wouldnt need to remove the brakes. i hate drums. I was just curious about one thing. Are you sure its a 32mm nut? That sounds huge.
Old Mar 7, 2008 | 02:06 AM
01S2king's Avatar
Default Re: (ooopseyesharted)
you dont have to remove the brakes since its drum. remove the drum then just pop off the gold dust cap in the middle with a thin flat head and a hammer. then remove the 32mm nut. the hub with bearing will pull rite off. replace with new hub assembly and torque to 180ft lbs.
Old Mar 7, 2008 | 06:33 AM
Default Re: (01S2king)
sweet. thanks man.
i bought the bearings assemblies this morning. $120 bucks.
hopefully this goes as smoothly as it sounds....LOL
Old Mar 7, 2008 | 03:27 PM
01S2king's Avatar
no problem. good luck
Old Mar 7, 2008 | 11:21 PM
EK45VTi's Avatar
When you tighten the nut after you replace the bearing, DO NOT OVERTIGHTEN it cos you will damage the bearing...
Tightening torque
181 Nm - 18.5 kgfm - 134 lbf-ft
And DON'T FORGET TO STAKE THE SPINDLE NUT SHOULDER AGAINST THE SPINDLE after you tighten the nut...
Old Mar 12, 2008 | 07:35 AM
Default Re: (EK45VTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK45VTi &raquo;</TD></TR><TR><TD CLASS="quote">When you tighten the nut after you replace the bearing, DO NOT OVERTIGHTEN it cos you will damage the bearing...
Tightening torque
And DON'T FORGET TO STAKE THE SPINDLE NUT SHOULDER AGAINST THE SPINDLE after you tighten the nut... </TD></TR></TABLE>
What does that last line mean.
what does "stake the spindle nut shoulder against the spindle" mean.
this isnt something I wanna screw up
Old Mar 12, 2008 | 07:42 AM
Malakai's Avatar
Ull see it when u look at it. The axle nut is punched down in one spot to prevent it from backing off. Just remember to punch it back down when u are finished.
Old Mar 12, 2008 | 07:49 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooopseyesharted &raquo;</TD></TR><TR><TD CLASS="quote">i was really hoping that i wouldnt need to remove the brakes. i hate drums. I was just curious about one thing. Are you sure its a 32mm nut? That sounds huge.</TD></TR></TABLE>
Yes it is a 32mm nut, no you do not need to remove the brake shoe assembly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooopseyesharted &raquo;</TD></TR><TR><TD CLASS="quote">sweet. thanks man.
hopefully this goes as smoothly as it sounds....LOL</TD></TR></TABLE>
Whoa!!! $120!!! That's expensive.
Old Mar 12, 2008 | 07:59 AM
EL Vap133's Avatar
Damn, you could have gotten rear disc brakes for $150-$175!
Old Mar 12, 2008 | 04:41 PM
Default Re: (Malakai)
Ok. i know what you are saying now. thanks alot man.
Old Mar 12, 2008 | 04:44 PM
Default Re: (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Whoa!!! $120!!! That's expensive.</TD></TR></TABLE>
How much should they be?
the front hub assemblies are 110each!!!!!
i didnt think it was too bad.
Old Mar 13, 2008 | 06:15 AM
BryanM.'s Avatar
Resident Gearhead
I just re-read your posts and didn't see a mention of you needing to do a front bearing, I thought you were saying you bought a rear bearing for $120 which is a rip off.
Old Mar 13, 2008 | 06:43 AM
i am doing the rears.
I was just comparing the front and rear pricing.
What should I spend for REAR bearings?
I got them at autozone. They were $60 each.
Old Mar 13, 2008 | 06:52 AM
BryanM.'s Avatar
Resident Gearhead
That's a decent price
roterx7
30
Mar 13, 2015 05:40 AM
sde780
40
May 15, 2012 10:32 AM
JaguarS4R
Honda Civic (2001 - 2005)
Oct 21, 2010 04:32 AM
typeeg
Jul 23, 2004 06:43 PM
shorti
10
Jan 14, 2003 12:22 PM
