D16Y8 upgrade path
Old Mar 6, 2008 | 08:19 AM
CivicExMaster's Avatar
Default D16Y8 upgrade path
Does anyone have ay good upgrades for a stock d16y8. got the intake already, but didnt know if anyone did upgrades they are happy with like (intake manifold, ignition. etc.) if anone has any good upgrades let me know
Old Mar 6, 2008 | 08:39 AM
96 EX's Avatar
Default Re: D16Y8 upgrade path (CivicExMaster)
Your best bet with the Y8 would be to turbo it... other than that anything is pretty much pointless. You could also do a swap to a DOHC whether its VTEC or not still would have more potential then the Y8. Also you should try using that red button in the top right hand corner called "Search". Hope this helps!
Old Mar 6, 2008 | 10:05 AM
spotscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet with the Y8 would be to turbo it... other than that anything is pretty much pointless. You could also do a swap to a DOHC whether its VTEC or not still would have more potential then the Y8. Also you should try using that red button in the top right hand corner called "Search". Hope this helps! </TD></TR></TABLE>
pretty much right. the only way your going to feel anything at all would be to boost it. but if you want low maintence go with a b-series NA.
byarbroo
10
Dec 3, 2012 09:40 PM
v8killa91
Jul 18, 2006 03:06 PM
awdriscol4
28
Mar 5, 2005 10:13 PM
Jaysun
Sep 24, 2003 10:33 PM
btlfedhatch
16
Jul 5, 2002 10:16 AM
