rear side window???
I've search for info on this but no luck. I wanted to know how do you adjust the rear side window on the civic hatch cause on my driver side the back end of the window is lower than towards the front so every time I turn or hit a dip the window squeaks.
It looks like the panel were the door jam is at just pops off and that is were you can adjust it right or remove it. I kind of pry on it with a plastic tool but I wasn't to sure so it looks like it was going to come off.
Any help would be appreciated thanks.
You should be able to adjust it after removing that panel. On the one I used to have, that panel was a bit brittle from age and broke off, but they're pretty cheap from Honda if yours breaks.
i had teh same problem .. i actualy took the little access panel off of the rear portion near that hatch where the window lock handle thing is at... there is like 3-4 screw just loosen those and you can adjust the hight in the rear it also wouldnt hurt to tighten tighten the screws that hold the window in on the front aswell...
hope this helps
Ant
hope this helps
Ant
