s2000 2.0L oil cooler work on bseries?
Old Mar 5, 2008 | 08:44 PM
killer_Bseries's Avatar
Default s2000 2.0L oil cooler work on bseries?
Part numbers aren't the same, but the O-ring from the 00 s2000 (62.4x3.1) is the same as the 00-01 Integra, but differnt part numbers. so i was wondering if any one kenw, if i could use the oil cooler from the s2000 on my b18c5. the s2k is much cheaper, espcially with those doscount on-line oem parts. s2k $244.83 vs type r 342.52. both prices are the discount prices. Please help!
oem s2k w/ b series bolt center or w/ s2k bolt center...help!????
i spun a rod bearing and have my old one, full of metal shavings. i dont want to even chance reusing it. btw i know im being a cheap ***, but i want to get my car running asap !!
Old Mar 5, 2008 | 08:57 PM
citrus3000psi's Avatar
Default Re: s2000 2.0L oil cooler work on bseries? (killer_Bseries)
If it has the same part number then you anwsered your own question already.
Old Mar 5, 2008 | 09:06 PM
Default Re: s2000 2.0L oil cooler work on bseries? (citrus3000psi)
None of the part numbers are the same. the s2k O-ring and the b18c5 have the same dimensions 62.4x3.1. which makes me want to believe that they are the same size. but just want to get some input or maybe a forsure answer.
Old Mar 6, 2008 | 12:14 AM
John M's Avatar
Hm i wouldn't mind knowing this myself
Old Mar 6, 2008 | 02:25 PM
PaChiLa Leader's Avatar
Default Re: s2000 2.0L oil cooler work on bseries? (John M)
anyone?
Old Mar 6, 2008 | 03:04 PM
neo_'s Avatar
Default Re: s2000 2.0L oil cooler work on bseries? (PaChiLa Leader)
I'm pretty sure the ports for a coolant lines face a different direction.
Your best bet would be to find one used, I wouldn't pay that much for an OEM oil cooler. And if you have no problem spending that much, I'd get an after market one that will perform a lot better.
And this thread is better suited in the Hybrid forum section.
Old Mar 6, 2008 | 03:15 PM
i was thinking aftermarket also. i did a small amount of research and the largest compliant was warm up time. don't really want to deal with that everytime my car has to warm up. i wont be tracking the car all the time either. oem i think fits my needs. thanks for the help too. im just going to have to oder the b series one.
Old Mar 7, 2008 | 08:19 AM
neo_'s Avatar
Default Re: (killer_Bseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killer_Bseries &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking aftermarket also. i did a small amount of research and the largest compliant was warm up time. don't really want to deal with that everytime my car has to warm up. </TD></TR></TABLE>
You can add a thermostat to it which will solve that problem.
Old Mar 7, 2008 | 09:17 AM
98DC2R's Avatar
I sent you a pm, I have one with only 9k on it.
Old Mar 7, 2008 | 09:31 AM
RTW DC2R's Avatar
aftermarket cooler would be much more efficient and cost about the same if not less.
Curated Content Editor
Honda-Tech News
May 3, 2019 10:29 AM
k1honda
Honda S2000
Jan 16, 2013 05:45 AM
RaVAGE00
Honda S2000
14
Feb 4, 2006 07:41 AM
westernPA
Honda S2000
Oct 25, 2004 11:50 AM
