ITR with Aftermarket hub/steering wheel
Old Jul 7, 2002 | 10:29 AM
Hard2Find's Avatar
Default ITR with Aftermarket hub/steering wheel
how do you wire up the HORN?
Old Jul 7, 2002 | 10:32 AM
migs's Avatar
Default Re: ITR with Aftermarket hub/steering wheel (Hard2Find)
Im not trying to flame at all but there was a recent topic on this, I forgot which forum. Some guy from Canada got it done with a little labor.
Cant think of the forum at this time.
Old Jul 7, 2002 | 02:24 PM
Comp97GSR's Avatar
Default Re: ITR with Aftermarket hub/steering wheel (MiGs)
If it is a MOMO wheel, buy a 88-91 (non srs air bag) civic hub. With little modification it will bolt up and then you need a flat piece of metal to use as a conductor for the horn. Wire it and bend it slightly to make contact with the hub, it SHOULD be good, it is the same technique to use on a JDM ITR wheel also. GOOD LUCK
[Modified by Comp97GSR, 11:24 PM 7/7/2002]
itslogz
Jun 19, 2009 11:11 PM
ka-nife_
Apr 2, 2006 05:36 AM
dutchman5
Feb 7, 2006 08:30 AM
92TypeR
Feb 19, 2005 12:29 PM
jonas
Feb 4, 2004 08:17 AM
