Will the amp take alot away from the battery and alty
i just bought a kicker sub with a ams of 150 and max of 300 and operation range is for peak is 300-799. i also got an amp with these specs:
2-Channel ZX-Series Power Amplifier
Peak Power Output: 400 watts approx.
RMS Power Ratings: 70 watts x 2 chan. @ 4 ohms
RMS Power Ratings: 100 watts x 2 chan. @ 2 ohms
RMS Power Ratings: 200 watts x 1 chan. @ 4 ohms
Low Impedance Operation
SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
MOSFET Power Supply
KickBass: 0-12 dB @ 40 Hz
Built-In Electronic Crossover: 12 dB High or Low-Pass operation (80 Hz)
High & Low level inputs
Custom tooled gold plated connectors
SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
Cast Aluminum EndKaps
Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
Warranty: 1 Year Onlinecarstereo.com warranty.
1 Year warranty from Onlinecarstereo.com implies that repairs must be returned to Onlinecarstereo.com, not the manufacturer. More information can be found in our help section under returns & warranties.
I understand that they will work perfect with each other but the real question is will it realy steal from my alty and battery oe even worse can it harm it?
Well thanks and if you need the model number here they are.
sub :
Kicker 07TC104
amp:
Kicker 06ZX200.2
Car: 2002 honda accord I4 vtec
MOSFET Power Supply
sub :
Kicker 07TC104
amp:
Kicker 06ZX200.2
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
you will be fine with that amp. Its better to be overpowered then under IMO. but 50 watts is no big deal. First because you will not be booming that hard to were it will be a major factor, Second music is dynamic, third because the amp is not going to be rms 200 watts all the time.
