itr pistons/ctr pistons?!?!?!
Old Mar 5, 2008 | 07:18 PM
civicking99's Avatar
Default itr pistons/ctr pistons?!?!?!
alright heres the thing, im putting together a motor and i had a gsr bottom end bored out to a set of itr pistons that i bought and i had the bottom end completely balanced and the crack knife edged. The cams that i want to go with (skunk2 pro2s) i would like to up my compression to get more power out if my cams, so would i be able to just drop a set of ctr pistons right into that bottom end without any troubles or are the bore sized different or will it throw off the balance of my bottom end...please help me out asap!!!
Old Mar 5, 2008 | 08:40 PM
inspyral's Avatar
Your cylinders should be bored/honed to the pistons' specs to ensure proper piston/wall clearance.
Old Mar 5, 2008 | 08:43 PM
well do ctr and itr have the same bore size i guess is what im asking
Old Mar 5, 2008 | 09:04 PM
inspyral's Avatar
Standard ITR and CTR pistons are both 81mm, and are also available oversized for rebuilds. However, even with pistons of the same diameter, the actual measurement of each individual piston can vary, which is why each cylinder needs to be bored/honed to its specific piston.
Old Mar 6, 2008 | 02:59 PM
ctr83's Avatar
Default Re: (inspyral)
whit ctr pistons your compression would be 12.042422. that's whit oem head gasket.
lickety_britches
Mar 21, 2008 07:31 PM
GSR_hatch936
11
Jan 10, 2008 12:06 PM
CaseBone
32
Apr 3, 2007 05:15 AM
PROJEKT DB2
Sep 29, 2006 09:18 AM
eddiecut
Feb 11, 2003 10:12 AM
