Fast help with Autozone rotors...
Well, I get the fronts on fine, but when I go to open the box to install the rears, they are the wrong ones!!
They are 4 lug!
The number on the box matches what their database says it should be online, so the guys at Autozone will be clueless when I tell them they aren't the right ones.
Can anyone tell me a different part number, or another car that uses the same rotors on the rear?
Thanks,
-David
They are 4 lug!The number on the box matches what their database says it should be online, so the guys at Autozone will be clueless when I tell them they aren't the right ones.
Thanks,
-David
I know 95 Legend front rotors are the same, but i have no clue about the rears......
Willard is the resident autozone guru, maybe he'll see this soon
why are you putting autozone rotors on your R, when you can get brembo blanks for 70$ a piece? if you still want to do this, the stock prlude rear rotors are the same i believe.
Thanks for the part number Jason, but those are the fronts. I'm looking for the rears. The part number they have on file for the R is 31149 for the rear, but those are 4 lug.
After calling several Autozone stores today I haven't been able to get any other part number that might work.
Has anyone actually seen rear rotors from Autozone?
Has anybody ever warped or worn out there rears?
I can't swear to it, but I don't think Will has either. If he hasn't worn them out, it's impossible to do
Damn..how can they be so cheap for the R? My 1990 Subaru Legacy L Wagon is in need of new front rotors...Autozone wasnts $39.99 EACH!
I highly doubt you would be able to install CRV front rotors on the rear of an R. Do R's have ventilated rear rotors? GS-R's have solid rear rotors, and the center rotor hat is MUCH bigger in back than in front.
Yeah, they are solid.
They aren't warped, but something is going on cause they look like hell with the top layer flaking off. Maybe it is pad material, or I glazed them, or something. I was going to put new ones on, turn the old ones, then have two sets, one for track and one for street.
tunes12
Jun 12, 2003 03:38 AM
Stryker908
10
Dec 3, 2002 06:59 AM
