Shake it shake it shake it shake it!!!!
Old Mar 5, 2008 | 06:23 PM
steveteggy92's Avatar
Default Shake it shake it shake it shake it!!!!
So, for as long as I've owned my car the motor always seemed a little bit shakey, runs perfectly but causes alot of vibration inside the car and under the hood.
Recently when I'm engaging the cluth I can feel my shifter torque a bit, so I think this would be the tranny/motor mount (the one inbetween the two?) Correct me if I'm wrong.
How hard is it to change, where exactly is it located and where is a good place to find one.
I had a nissan that did this, the shifter torqued quite a bit when you shifted gears and a bolt ended up shearing off into a mount and it was a real hassle to fix. That was a long time ago though.
Old Mar 6, 2008 | 02:29 PM
vshavoc's Avatar
Default Re: Shake it shake it shake it shake it!!!! (steveteggy92)
It's probably the rear motor mount. It's a bitch to change but it's possible to do. Use energy motor mount inserts on it when you install it and hopefully that will help it from braking again.
Old Mar 11, 2008 | 10:15 AM
Default Re: Shake it shake it shake it shake it!!!! (vshavoc)
Is the rear one the one thats between the motor and tranny? WHere exactly is it, and whats involved in changing it.
Old Mar 11, 2008 | 10:28 AM
yc_dc4mar's Avatar
i dont think its that one. bec mine is done. the rubber or w/e is just free floating in the mount and i dont shake like that.
Old Mar 11, 2008 | 10:35 AM
Default Re: Shake it shake it shake it shake it!!!! (yc_dc4mar)
I get a weird shuddering sometimes when I'm taking off from a stop or if I accellerate hard from a low rpm, like from 2k to 3k I'll get a bit of a shudder.
Old Mar 11, 2008 | 10:40 AM
yc_dc4mar's Avatar
ehh..then maybe its that one. idk its weird but 2 of mine are broken and it doesn't shake as bad as i though. a little shudder here and there nothing big.
airikkCRX
Jul 27, 2008 07:52 AM
Team 4R
Jan 12, 2004 08:54 PM
gsrstyle
Dec 23, 2002 02:27 AM
TeamFlip02
Sep 12, 2002 07:49 AM
madchiller
Jul 8, 2002 06:39 PM
