GSR dash bulb out
Old Jul 7, 2002 | 09:58 AM
Projected's Avatar
Default GSR dash bulb out
I'm purchasing a used 95 GSR, I was told the dash bulb for the tach is out. The previous owner claims that Acura charges about $200 to repair. How difficult is this to repair and has anyone done it? Thanks for any help.
Old Jul 7, 2002 | 10:05 AM
migs's Avatar
Default Re: GSR dash bulb out (Projected)
Requires removal of a about 5-6 screws. Then you unplug the back of the harness from the cluster, fine the bulb which is burnt out. Then replace. The bulbs from the dealer should cost no more than $5/piece
Old Jul 7, 2002 | 05:03 PM
Projected's Avatar
Default Re: GSR dash bulb out (MiGs)
Sounds easy enough, thanks for your help.
Old Jul 7, 2002 | 05:10 PM
Tanner's Avatar
New User
You can also replace the bulbs with colored bulbs I run red in mine.. all the numbers light up red... looks pretty cool...IMO
Old Jul 7, 2002 | 05:25 PM
IN VTEC's Avatar
SAE 168 or 194 are the replacements.
Be careful taking hte condom off. I tore one in half when I replaced mine.
And, to loosen the gauge cluster shroud after removing the two screws.....put the strg wheel all the way down, put your hands palm up, and pull with your finger tips at the bottom of the shroud just above the strg wheel column.
I used Polarg M-4's with the stock blue condoms.
Old Jul 13, 2002 | 08:41 PM
LillDragun's Avatar
Default Re: GSR dash bulb out (IN VTEC)
what are the blue condoms for?? yeah i did the red and it looks so tyte.
Old Jul 13, 2002 | 08:57 PM
IN VTEC's Avatar
Default Re: GSR dash bulb out (LillDragun)
They come already on top of the stock bulbs.
They might have stopped using them somewhere down the line b/c my friend's '01 ITR didn't have them.
sinister357
Mar 11, 2009 12:27 PM
tweek_boii
Dec 14, 2007 04:12 AM
Blahblah718293
Feb 20, 2007 06:30 PM
lahight
Feb 26, 2003 01:37 PM
StockTeg
Nov 21, 2001 02:35 PM
