OBD0 - OBDI Question
Old Jul 7, 2002 | 09:00 AM
02WRX's Avatar
Default OBD0 - OBDI Question
Alternators - are the connections on an b-series OBD0 & OBDI alternator the same? I replaced the alternator on my b16a - it's good at idle - between 13.6 & 13.85 volts depending on the accessories on. At about 6.5k rpm, the charging light comes on & stays on until the revs drop. I had replaced the old alternator with a 65 amp 91 LS alternator & think that the alternator's just too weak to deal with the VTEC requirements. I'd like to change to a 94 GSR alternator, since they're 90 amps, but need to know if it will plug in!
Thanks,
Eric
Old Jul 7, 2002 | 07:35 PM
02WRX's Avatar
Default Re: OBD0 - OBDI Question (90CivicEX)
ttt
Old Jul 7, 2002 | 09:00 PM
02WRX's Avatar
Default Re: OBD0 - OBDI Question (EVIL Teken)
hmm, but 92-93 are OBD-I, right? The cost difference isn't too huge a deal, but will the alternator plug into the harness?
Eric
Old Jul 8, 2002 | 03:26 AM
kenji's Avatar
25 Year Member
The plugs are the same and the alternators are interchangeable.
-kenji
Old Jul 8, 2002 | 06:10 AM
02WRX's Avatar
Default Re: OBD0 - OBDI Question (kenji)
That's what I needed to know, thanks! Woulda been a pain in the *** to get everything off & find out it wouldn't work...
Eric
Old Jul 8, 2002 | 11:11 AM
dogpile5's Avatar
25 Year Member
-kenji
i concurr. i had a alternator go bad on my b16, and pulled one from a b16a in an engine warehouse. plugged in, works fine, no CEL lights, etc... i am also using a UR crank pulley.
Runnin_Free
Apr 6, 2011 03:58 PM
Runnin_Free
Apr 1, 2011 02:28 PM
shiithook
Jul 11, 2002 04:53 PM
