H4 HID Kit HELP *pics*
So I just got a new HID kit. This looks a little different then my current one. I tried to hook it up but I have no idea what the 2 wires with the connectors are. or the little plug piece.
I attached two pictures. IF anyone knows how to connect this to a 02 civic H4 headlight that would be excellent.
ok i jus did this instaill in my car...unplug that clip that goes to the blue/blk wire thats in the ballast, then plug ur stock clip that goes into the back of ur oem headlight bulb into that.
pretty much take ur head light bulb out of headlight, unplug the bulb from car light harness and then plug that clip into the ballast. your bulb signal has to go into the ballast then out the wires that connect to the HID bulb, which you will now hook into ur factory headlight. that wire is jus an extension harness for the factory clip
GQ 05YellowEVO8
Feb 9, 2002 07:19 AM
