Car bogging and Tach jumping
Old Mar 5, 2008 | 12:21 PM
matmcg's Avatar
Default Car bogging and Tach jumping
So when I drive its very un smooth and the tach jumps around a bit really annoying sometimes felel like i am gonna stall on take off
some help plz
Old Mar 5, 2008 | 01:13 PM
matmcg's Avatar
bump
Old Mar 5, 2008 | 01:30 PM
crxstylin's Avatar
Default Re: (matmcg)
sounds like your ignition coil is going bad, i would go ahead and buy one before it leaves you stranded
Old Mar 5, 2008 | 04:52 PM
matmcg's Avatar
I jsut got a whole brand new distributor....
Old Mar 5, 2008 | 04:57 PM
denraweb's Avatar
and what happened?
Old Mar 5, 2008 | 04:59 PM
matmcg's Avatar
I had to buy a new one because the old one wouldnt start the car and I broke some parts taking it apart to replace parts
so i got this brand new one
it started her right up but it is doing this annoying thing !! and i dont want to go have to spend another 90 dollars on a new coil
Old Mar 5, 2008 | 05:00 PM
DA_9's Avatar
Default Re: (denraweb)
Either its the dizzy, but uve said u replaced it...your timing, the fuel filter (VERY LIKELY) the fuel pump (ALSO LIKELY) or if its swapped its running rich (not so likely if ur stock at all). So, i'd start by checking your timing, then the fuel filter replacement and then the fuel pump. Im sure somethin will do the trick. Let us know.
Old Mar 5, 2008 | 06:06 PM
crxstylin's Avatar
My friend bought a new distributor the other day. It started to do this and I told him to go get a new one. He didnt listen and it stranded him in the middle of no where and had to be towed at the expense of $150 since the parts stores around him were closed
Old Mar 6, 2008 | 07:27 PM
matmcg's Avatar
PROBLEM SOLVED:
So I went to go and take a look at what is going on the distributor and first thing I notice is that my Side skirt is gone.... Weird someone must have stolen it I think.
So I go to pop the hood and i see my distributor is not even attached properly there is only one bolt left on and the contact is not very good ... so [freak]ing thieves tried to steal it but didnt have enough time. So i tied it up with some string and of course the bogging went away
so i drive to the stealership 8 bux for the bolts FTL
Old Mar 7, 2008 | 01:03 AM
oldsk00Lfunk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">PROBLEM SOLVED:
So i tied it up with some string and of course the bogging went away</TD></TR></TABLE>
FTW! hahahaha
Old Mar 7, 2008 | 02:07 AM
matmcg's Avatar
LOL quick fixxxx gotta order them bolts though scared the strings gonna get too hot and catch fire
Josh Jennings
Oct 30, 2016 03:35 PM
j_mee_5
Aug 17, 2010 09:47 AM
drockcrx
Nov 10, 2009 11:49 AM
Dorby
Mar 26, 2006 06:19 AM
Lscivichatch92
Mar 31, 2004 08:22 PM
