what ecu to use? gsr motor
Old Mar 5, 2008 | 12:03 PM
JDMB18CEJ1's Avatar
* B A N N E D *
Default what ecu to use? gsr motor
well last nights some muthatf*ckers jacked me. it was a pr3 ecu that came with the motor.my motor is a jdm gsr motor obd-1,skunk2 pro manifold jdm itr throttle body. i was told i couldnt use the stock p72 cuz of my single runner manifold. help me out here what ecu should i get? stock p28 will work right? thx
Old Mar 5, 2008 | 12:32 PM
sorrule's Avatar
Default Re: what ecu to use? gsr motor (JDMB18CEJ1)
a p28 is an obd1 ex/si single cam ecu. I don't see why you can't run a stock p72. Your motor is pretty much stock. Even without you secondaries, a p72 will work better than most other ecu's. If you get a p28 you'll have to chip it and tune it for your motor. It's probably more cost effective if you just run a stock p72 untill you do something major. Either ecu is chippable.
Old Mar 5, 2008 | 12:45 PM
JDMB18CEJ1's Avatar
* B A N N E D *
Default Re: what ecu to use? gsr motor (sorrule)
thanks
Mramirez199112
Mar 4, 2019 05:37 AM
element1791
Engine Management and Tuning
Nov 24, 2014 11:58 AM
outage
Jan 28, 2013 01:50 PM
DA STRIKER
Feb 4, 2011 03:49 PM
whiteteggy44
Jan 31, 2011 02:00 PM
