H22A4 into EK Hatch
Old Mar 5, 2008 | 09:20 AM
5lugSlug's Avatar
Default H22A4 into EK Hatch
Currently Owning:
- Avid Mounts
- Skunk2 IM
- Skunk2 TB
- Golden Eagle Fuel Rail
- OEM Honda Headgasket
- OEM Honda IM Gasket
- OEM Honda TB Gasket
- OEM Honda EM Gasket
- OEM Honda Waterpump
- New Radiator
- Slim Fan
- Mugen 4-2-1 Exhaust w/ flex pipe
- AEM Pulleys
- DSS Stage 0 Axles
- Hondata S200
- Phearable conversion harness
Waiting to buy:
- FPR
Is there anything else I will need or I should buy before starting the swap?
I want this to go smooth and quick as possible.
Old Mar 5, 2008 | 01:20 PM
botlebruiser's Avatar
Default Re: H22A4 into EK Hatch (5lugSlug)
You will need shifter cables and a shifter box out of an accord or a prelude. Be careful with the pulleys. My h22a1 came with an aem alternator pulley and it hit the headlight adjustment. You will need the h22 injector wires and an h22 alternator plug as well. Im sure im forgeting a few things, ill post again if I think of anything else.
Old Mar 5, 2008 | 01:46 PM
5lugSlug's Avatar
wont the injector wires alrdy be on the motor?
Old Mar 10, 2008 | 03:36 PM
5lugSlug's Avatar
Alright final questions, motor is going in this weekend!!
- What radiator hoses do I need? I have a oem replacement radiator (98 EK) and 97 h22
- Whats that belt number for h22a4 without powersteering and without A/C?
Old Mar 12, 2008 | 06:49 PM
bassysingh's Avatar
not sure about the belt but for the hoses the stock h22 hoses will work. you'll have to cut the top and bottom lower radiator hoses to have them fit. be sure to use the screw type clamps since the radiator inlets will be smaller than the H22 hoses.
Also be sure to get a new OEM heater hose from Honda that attaches to the water inlet tube on the back of the engine. I checked and couldn't find one at a local part store. this will prove to be a bitch to change once the motor is in.... GL
Old Mar 13, 2008 | 08:08 PM
5lugSlug's Avatar
^^ thanks taking that into consideration!
judd_123
Oct 17, 2010 09:11 PM
5lugSlug
14
Mar 5, 2008 06:46 AM
abnaasefmb
Sep 7, 2006 04:18 PM
blowbyu24
Oct 10, 2005 08:57 PM
Toda Party
Sep 1, 2005 05:42 AM
