why cant i get into gear?
Old Mar 5, 2008 | 09:15 AM
Slosc2's Avatar
Default why cant i get into gear?
Like topic states. d16z6, si cable trans. car goes into gear when vehicle is off. if i start the car in gear and release the clutch it moves. if i go to put the car in gear while the car is running, reverse grinds, and it wont go into any gear. really tired of [freak]ing with this thing.
Old Mar 5, 2008 | 09:22 AM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: why cant i get into gear? (Slosc2)
has it always done that??
it sounds like several different things, not exactly sure.
possibly the biggest thing is the clutch.
gears might also be grinding.
Old Mar 5, 2008 | 09:35 AM
Slosc2's Avatar
Default Re: why cant i get into gear? (spikehead221)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spikehead221 &raquo;</TD></TR><TR><TD CLASS="quote">has it always done that??
gears might also be grinding.</TD></TR></TABLE>
I just purchased the vehicle it had everything in it, but would not run due to the wiring. I finished up the wiring, got everything to run properly with no cel's, and now i discover it wont go into gear. I think the prior owner (dumbass btw) left the clutch flywheel and PP from the z6 in there. Any chance this would cause that?
Old Mar 5, 2008 | 09:37 AM
it wouldnt hurt to try.
i am kinda out of ideas now
dr_latino999's Avatar
Clutch cable properly adjusted? Has the clutch pedal pivot bent/broke from the assembly?
phaphon's Avatar
this happen to me you might needa adjust your clutch loosen it i had to loosen mine alot...also where your shift linkage connects to the shifter might me a little to tight...im just letting to know what i did to correct my problem when i had the same problem
Old Mar 5, 2008 | 09:50 AM
Slosc2's Avatar
Default Re: why cant i get into gear? (phaphon)
I adjusted the hell out of the cable, that all functions right, the linkage is good as i can move it freely between gears when the car is off.
Old Mar 5, 2008 | 10:02 AM
phaphon's Avatar
still doesnt work??? maybe the throwout bearing or clutch as the dude said? did you loosen the clutch cable hella ??? cause i had to loosen mines alot when i change my clutch and flywheel last time
Old Mar 5, 2008 | 10:50 AM
AK_CRX's Avatar
Definately worn clutch, when the throwout bearing wears a deep groove into the pressure plate it no longer have enough throw to disengage.... Constant traction of the clutch, constant spining of your tranny internals= not being able to shift. I've run into this on a few high mileage m/t honda's. New clutch plus throwout bearing should fix this for sure given what you've told us
Old Mar 5, 2008 | 12:24 PM
Slosc2's Avatar
Default Re: why cant i get into gear? (AK_CRX)
working on that now! I actually drove it from my small garage, to the larger garage where the cobra and saleen sleep so I could get it up in the air and have more room.
HopefulVtec
Jul 16, 2015 07:15 PM
NoPainNoGain
Honda Civic (2006 - 2015)
21
Feb 2, 2007 10:37 AM
sing
Jan 4, 2007 02:12 PM
philkehn
Oct 27, 2006 06:58 AM
Austin
Dec 1, 2003 12:04 PM
