FS:Turbo Part Out (NY)
<FONT COLOR=""Red""><U>Turbo: ( the one in my signatureis the actual one)</U></FONT>
Product Information
GARRETT 57 trim
Compressor Specs:-57 trim compressor wheel
-0.60AR compressor housing
- Flow Rate 50lb/min
Turbine Specifications:-Stage 3 turbine wheel
-0.63 A/R. turbine housing
-4 bolt standard turbine discharge
CHRA Specifications:
-360 degree thrust bearing standard.
-Oil cooled&lubricated center section.
<U>supportable of 475whp!</U> Used for roughly about a 100 miles NO SHAFT PLAY LOOKS NEW. <FONT COLOR=""Red"">$450</FONT>
<FONT COLOR=""Red"">Intercooler with Piping for eg plus silicon couplers and t-bolt clamps:</FONT>
Intercooler Dimensions
Core Width: 22" (overall width with end tanks: 30")
Core Height: 9"
Core Thickness: 3.25"
Inlet Diameter: 3"
Outlet Diameter: 3"
Inlet/Outlet Neck Location: Offset
Intercooler Specifications:
Approx. Flow Rate for this intercooler: 725 CFM at 1.5PSi pressure drop
Approx. HP Rating for this intercooler: 550 HP
Intercooler looks brand new and has no dented fins was used on car for like 15 miles.
piping for Intercooler is 2.5" and has silicon couplers, reducers, and t-bolt clamps FOR eg but will fit ek and dc chassis
<FONT COLOR=""red"">$320</FONT>
<FONT COLOR=""red"">BOV Greddy type S (Discontinued):</FONT>
GReddy has lost the Manufacturing Exclusivity on the Type S Blow Off Valve
Diaphram is in great shape fully functional.
$200
Boost Gauge:
BRAND NEW IN BOX
The S7 EL technology of style, clarity and multi-colored: consisting of super white, blue, red, and orange are introduced through the S7 Race Gauges. The S7 Race Gauges compliment the S7 Series of products with its useful measurements such as boost.
Each gauge is
precision crafted for accuracy as
well as designed for maximum
visual appeal. / 52mm
$45
D-series Ram horn Manifold w/ tial flange and 3inch Down pipe with flex pipe + 2 bungs for 02, egt, a/f sensors
$350
and for ***** and giggles: a blown t28 turbo rebuildable. 25 bucks.
Product Information
GARRETT 57 trim
Core Height: 9"
Inlet Diameter: 3"
Outlet Diameter: 3"
$200
Boost Gauge:
BRAND NEW IN BOX
Each gauge is
$45
$350
TheMidasTouch
May 17, 2007 07:58 AM
