d16z6 help
Old Mar 5, 2008 | 07:18 AM
tc91crx's Avatar
Default d16z6 help
I need to disconnect the pipe comming from the water pump to the thermostat and I need to disconnect it at the housing for the thermostat on a d16z6 how is this done? does it just pull out or is it secured in there? thanks.
Old Mar 5, 2008 | 08:00 AM
1992Si's Avatar
It's only held in there by the O-rings, just spray a little silcone on the ends to help it break free.
The pipe is called the water transfer tube.
Old Mar 5, 2008 | 09:05 AM
blk92_d16's Avatar
^Yep! There might be one obvious bracket with a bolt for it...but other than that it'll require a bit of pulling.
Old Mar 5, 2008 | 09:14 AM
JDM_SOHC's Avatar
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">^Yep! There might be one obvious bracket with a bolt for it...but other than that it'll require a bit of pulling. </TD></TR></TABLE>
mine didnt... i just disconnected thermostat housing, one hose going into the water transfer tube, an than just pulled an that **** came right out...
mine somehow sprung a hole right in the middle &lt;see pic below&gt;, so i found one in my garage fulla old junk parts luckily but i dont see a junkyard chargin more than 20 for one...
OrangeBoost
Mar 24, 2005 08:43 AM
EK k kay
Dec 22, 2004 11:56 PM
redcivic
Oct 14, 2003 08:16 AM
