Type R throttle body on B16 in CRX
could you possibly post a pic of the "solenoid" on the map sensor you're referring to? i'm not familiar with the crx map sensor, and its location, but hopefully some more info from you could help us help you.
if the plugs on the two map sensors (crx vs. itr) are the same, you could just extend the wiring and plug and play. this would mean you'd have to have the actual map sensor that sits on top of the itr throttle body.
that solenoid is a seperate part from the MAP sensor.....ignore it and just extend the MAP wire senor's plug to the MAP sensor on top of the ITR tb.
ITR throttle body is pointless on B16 intake manifold. You will not flow any more air into the IM than what it's capacity is regardless of the TB bore.
killacam661
11
Dec 2, 2007 04:41 PM
EgSalad
Jun 6, 2007 12:12 PM
Pooper
Oct 16, 2006 09:19 PM
