Easy Mods for a 2000 civic Si
Old Mar 5, 2008 | 05:18 AM
kidcruze's Avatar
Default Easy Mods for a 2000 civic Si
I have a aem intake, an exuast and header and want to do a few low cost easy mods to give it a little more pick up
Old Mar 5, 2008 | 05:20 AM
Dkober101's Avatar
Default Re: Easy Mods for a 2000 civic Si (kidcruze)
blow it up and gett a new one oooorrrrr turbo remember manddy i have some one with an STS wiht timer for 2300
Old Mar 5, 2008 | 05:24 AM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidcruze &raquo;</TD></TR><TR><TD CLASS="quote">I have a aem intake, an exuast and header and want to do a few low cost easy mods to give it a little more pick up </TD></TR></TABLE>
so you want the cheap mods? besides i/h/e, you could upgrade your ignition and fuel system. otherwise, your stuck getting the more expensive mods...you have already bought the cheaper mods. so i would say a set if ctr cams or just turbo it. either way, its gonna add up. good luck.
Old Mar 5, 2008 | 05:47 AM
MurdersV8s's Avatar
Default Re: Easy Mods for a 2000 civic Si (slo_hatch)
Buying ignition or fuel upgrades would be a waste with what the op has. With basic bolt ons there is no need to modify your fuel or ignition. Stock fuel set ups can handle up to about 190whp. While honda ignitions don't have to be replaced unless you are running a high amount of power.
If you haven't upgraded your suspension I suggest you do that first. This is were you would notice the most improvements.
After that start saving and then you can purchase some internals or a turbo kit.
Old Mar 5, 2008 | 05:54 AM
slo_hatch's Avatar
Default Re: Easy Mods for a 2000 civic Si (MurdersV8s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MurdersV8s &raquo;</TD></TR><TR><TD CLASS="quote">Buying ignition or fuel upgrades would be a waste with what the op has. With basic bolt ons there is no need to modify your fuel or ignition. Stock fuel set ups can handle up to about 190whp. While honda ignitions don't have to be replaced unless you are running a high amount of power.
suspension is not gonna give him more pick up. and i was just offering suggestions because i know that stuff is cheaper than cams or internals or a turbo. but i think the OP should just go for turbo.
RetroGamer
Aug 2, 2011 02:21 PM
bottomend
Mar 29, 2006 09:14 AM
wkv883
15
Aug 30, 2004 06:46 AM
Boosteddc2gsr
Jan 13, 2004 10:30 AM
L4NDO
Mar 28, 2002 07:11 PM
