ZC EXTREMLY HIGH IDLE
Old Mar 5, 2008 | 04:38 AM
liloldchevyvan's Avatar
Default ZC EXTREMLY HIGH IDLE
when i start my car idle jumps up to around 6500 rpms. i have tried a different IACV and ecu. if i pull the connector out of the valve it idles iradic of course but it doesnt jump as high. also when its idling that high the throttle plate isnt opening. the crx is a SI it has the SI wiring harness in it. does anyone have any ideas thank you.
Old Mar 5, 2008 | 05:34 AM
zccr-xsi's Avatar
have u tried adjusting your idle?also try adjusting your throttle cable maybe its to tight and its pulling on the cable which will make your revs go up.
Old Mar 5, 2008 | 11:46 AM
de1991hatch's Avatar
Default Re: (zccr-xsi)
very possible that it could be a vaccum leak, maybe the throttle body gasket?(happened to me) check all your vaccum lines over
Old Apr 15, 2008 | 08:33 PM
civicsnake90's Avatar
Default Re: (de1991hatch)
I have the same problem on my b18a1 that i just rebuilt and i have no vacuum leaks so i am so lost of what it could be.
Old Apr 15, 2008 | 09:20 PM
ludesrv's Avatar
Adjust your TPS sensor as per your honda manual. Should help.
Old Apr 15, 2008 | 09:33 PM
traxxasx's Avatar
Pull you FITV off and reassemble the inside of it.
99% thats the problem.
Old Apr 15, 2008 | 09:43 PM
goodoldave_13's Avatar
have you checked everything for vacume leaks? also my IAC valve actually came out of the intake manifold once, and made my car do the same thing.
freddy chavez
Apr 8, 2013 07:40 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
jwizzie2001
Oct 24, 2008 05:46 PM
BJA86
Oct 5, 2008 01:54 PM
CRXCIVICMIX
Jul 13, 2006 06:54 AM
