turn signals down.... help!
my four way flashers work but i cannot seem to get my actuall turn signals to go. they were working before. i checked all the fuses and none seem to be bad. what is the problem here? i have a 1995 honda civic with a complete GSR swap. please reply giving information on how to fix this in depth. thanks.
would it just go bad out of know where.. cause they have been working before.. do u think it may be a wiring problem?.. if its the switch. how hard is it to replace?
switch has two little screws and two plugs..after those are out should just slide out....im having a similar problem but my signals will work when the lights are off and not on....hazards stay on when my lights are on
yeah check ur internal switch first and after u replace that and if ur turn signals still don't work i suggest check ur fuses again. that's all i can think of
egboy94
Feb 26, 2011 05:52 AM
layinlow4dr
Jan 13, 2010 08:08 AM
