is it necessary to separate the transmission to drop the oil pan?
Old Mar 5, 2008 | 02:22 AM
silverskateEF9's Avatar
Default is it necessary to separate the transmission to drop the oil pan?
Looking underneath my Type R engine, it looks like the right side of the oil pan is tucked inside the transmission bell housing, with the bolts necessary to drop the pan on that side out of view. I would like to run the Mugen baffled oil pan, is it necessary to separate the tranny to get access to the stock pan?
Old Mar 5, 2008 | 03:38 AM
Ed 341's Avatar
Default Re: is it necessary to separate the transmission to drop the oil pan? (silverskateEF9)
Nope, just remove the engine block stiffener, I think its held on by 5-6 bolts. You have to take off the exhaust manifold too.
That reminds me I need to put mine back on!
Old Mar 5, 2008 | 07:07 AM
jomama's Avatar
^ed's correct. you don't have to.
just have to remove one stiffener, i believe. i had to do this to my daily gsr and i had 2 i had to remove... but after i got the header off and the stiffeners off... which were all just a PITA to get off, and unbolted the nuts/bolts to the pan, it just popped right off. GL.
Old Mar 5, 2008 | 07:31 AM
pvt_awol's Avatar
Default Re: (jomama)
a sad day for me.
Until about 3 months ago (when I first bought my '00 Si) I didn't even know that these engines had a stiffener to the tranny. I've owned, and gone through too many to count B swaps..... and none have had the stiffener. (Even my R's is missing)
So, I gotta ask, how important is it? Why would they have all been taken off? And are there limits to when they can be used? example- I thought I heard that a B18c with a Civic tranny would not allow the stiffener... yet, my stock '00 Si has one.?
Old Mar 5, 2008 | 09:37 AM
CW-ITR's Avatar
Default Re: (pvt_awol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pvt_awol &raquo;</TD></TR><TR><TD CLASS="quote">a sad day for me.
So, I gotta ask, how important is it? Why would they have all been taken off? And are there limits to when they can be used? example- I thought I heard that a B18c with a Civic tranny would not allow the stiffener... yet, my stock '00 Si has one.?</TD></TR></TABLE>With it on, certain headers won't clear it. Other than that, it should be on to ...well, stiff up the tranny
Old Mar 5, 2008 | 10:01 AM
jgirard's Avatar
Default Re: (CW-ITR)
wouldn't it also protect the flywheel whichh I believe is what is directly behind it?
Old Mar 5, 2008 | 10:07 AM
cmdr430's Avatar
Default Re: (jgirard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't it also protect the flywheel whichh I believe is what is directly behind it?</TD></TR></TABLE>
yep
you can use the gsr cover if you have a header that will not clear the itr brace
Old Mar 5, 2008 | 11:07 AM
pvt_awol's Avatar
Default Re: (cmdr430)
I suppose that explains why mine is missing on my R. (the Hytech header doesn't clear it I guess?)
but it doesn't explain why every other B-series car I've owned, or swap I've purchased had it missing.
Now I'm mad at all the people who sold me messed up stuff! Bastards!
Old Mar 5, 2008 | 01:21 PM
Kavehman's Avatar
Learn to read. Only ITR's came with it. Not every B series has the heavey duty tranny brace.
Old Mar 5, 2008 | 02:00 PM
jomama's Avatar
Default Re: (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">Learn to read. Only ITR's came with it. Not every B series has the heavey duty tranny brace.</TD></TR></TABLE>
i'm not sure what you're referring to...or who, but if you're talking about stiffeners, not only ITRs had them. (maybe we're just on different pages )like i said, i had TWO i had to remove on my daily GSR last night and one was particulary a PITA so i remember quite clearly.
Old Mar 5, 2008 | 03:36 PM
SuckMyDOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">
i'm not sure what you're referring to...or who, but if you're talking about stiffeners, not only ITRs had them. (maybe we're just on different pages )like i said, i had TWO i had to remove on my daily GSR last night and one was particulary a PITA so i remember quite clearly. </TD></TR></TABLE>
Correction, you had covers, not braces/stiffeners. The GSR/LS covers are just a thin piece of metal to cover and protect the flywheel. ITR's came with big *** chunks of metal to act as a stiffener/brace
Old Mar 5, 2008 | 03:47 PM
ITR.#1446's Avatar
are you sure you know what the itr brace looks like it a huge aluminum brace its not the two legs every other b series has that connects the block to transmission.
Old Mar 5, 2008 | 05:58 PM
d.n.d.'s Avatar
what Kavehman said is true. i remember reading the technical aspects of the ITR right down to the engine, and it said the ITR had a block stiffener. although i had no idea what to look for, the diagram just pointed to a spot next to the oil dipstick.
not to thread jack, this brings me to a quick question i have. where IS the block stiffener? part #10?? when i could not make out where it was, i just assumed it was sorta integrated with the block.
Old Mar 6, 2008 | 06:47 PM
kaj's Avatar
kaj
Default Re: (SuckMyDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">
Correction, you had covers, not braces/stiffeners. The GSR/LS covers are just a thin piece of metal to cover and protect the flywheel. ITR's came with big *** chunks of metal to act as a stiffener/brace</TD></TR></TABLE>
my GSR had part numbers 10 and/or 11 (forget if i had them both or just one.. thinking both) from the pic above. those are not covers. they are braces/stiffeners/what ever you want to call them. also: yes. it did have a black sheetmetal cover.
Old Mar 6, 2008 | 06:48 PM
kaj's Avatar
kaj
Default Re: (d.n.d.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d.n.d. &raquo;</TD></TR><TR><TD CLASS="quote"> part #10??</TD></TR></TABLE>
yes.
tamadrumr88
Jan 13, 2010 04:26 PM
Propulsion
Jan 9, 2007 03:49 AM
Cuong-nutz
Nov 4, 2005 10:27 PM
92hondalude
Sep 27, 2005 09:26 PM
dynomax27
Oct 15, 2002 04:22 PM
