speed sensor problem
Old Mar 4, 2008 | 11:15 PM
b frisco's Avatar
Default speed sensor problem
i have no speed sensor.i have a 1995 gsr tranny with LSD the gear (teeth) inside my tranny is broken coz i put a wrong speed sensor coz someone put a automatic VSS. now i have the right speed sensor but i havent tried yet because inm scared of making it worst. can i get a magnetic speed sensor. pls someone help me thank you!
Old Mar 4, 2008 | 11:21 PM
b frisco's Avatar
Default Re: speed sensor problem (b frisco)
pls someone help me. where can i buy a magntic speed sensor
Old Mar 5, 2008 | 05:30 PM
hard_boiled_EG's Avatar
anything broken that is metal inside the trans will go to the bottom and will be collected by the magnet that is already placed in the transmission, if it's plastic, your gears will just grind it up and you'll never see it again, so just put ur vss on and go for a drive, if your still scared change your transmission oil then go for a drive. and i've never heard of a magntic vss???
Old Mar 5, 2008 | 10:11 PM
b frisco's Avatar
Default Re: speed sensor problem (hard_boiled_EG)
i went to R CREW they check my ring gear they told me its realy bad and cannot be fixed they tried to put the right VSS but it wont go through.So i talk to my friend he told me we need to shave the tip of the VSS to match the messed ring gear. is that possible will it work. thank you
variablevalve
Aug 17, 2020 10:41 AM
matavtec
Jun 12, 2009 05:14 PM
thannon2
22
Jan 20, 2009 08:04 PM
thannon2
Jan 16, 2009 01:59 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
