New issue when starting...
Old Mar 4, 2008 | 08:02 PM
ITR_HO's Avatar
Default New issue when starting...
So my car just recently starting doing this upon start up, sometimes it'll start right up with no issues and other times as I crank it everything just turns off...IE lights, cluster, radio as if it had reset itself. So to get around this issue ive been having to disconnect the battery cables from the battery and reconnect them. After I do this the car will start right up.
Things ive been noticing.
-Clock resets to 1:00, not sure if that’s normal?
-sometimes I hear a click noise when trying to start it and everything turns off.
-not the battery cause I got a new one.
Starter maybe? alternator maybe? ideas? Im starting to think its something else cause everything goes completely dead until i unplug the battery cables and plug it back.
Old Mar 8, 2013 | 05:58 AM
TM06's Avatar
Default Re: New issue when starting...
I know this is an old thread, however; this is the exact problem I am having at the moment in my h22a ej8. Does anyone know what the solution to this problem is? Thanks in advance!
ls19integra95
Dec 15, 2007 07:50 PM
Mavrick
12
May 9, 2006 07:48 PM
YAY!
Feb 15, 2004 11:13 PM
TurboTypeR98
May 27, 2002 08:26 PM
