How do you clean dirty trunk??
Old Mar 4, 2008 | 07:41 PM
kcjohnnyboy's Avatar
Default How do you clean dirty trunk??
I just got a civic sedan 97 and the previous owner did not take care of it and the trunk is a mess. It is covered in some black gewey stuff that hardened and some parts of it sort of soft also. If you guys know what I'm talking about, how do you clean this up? Will simple green do the job?
Old Mar 4, 2008 | 08:43 PM
NOFX's Avatar
H-T White Ops
Take photos and get back to us.
Old Mar 4, 2008 | 08:48 PM
EkFG's Avatar
sounds like tar? is it on the carpet or hard plastic?
Old Mar 4, 2008 | 08:49 PM
i will try to do that soon
Old Mar 4, 2008 | 08:50 PM
Default Re: (EkFG)
its in the trunk where the spare tire is and all around the trunk, there is no carpet back there or anything just a spare tire and pure nastiness
Old Mar 4, 2008 | 10:17 PM
shadohconspiracy's Avatar
dry ice
Old Mar 4, 2008 | 10:53 PM
NOFX's Avatar
H-T White Ops
Default Re: (shadohconspiracy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohconspiracy &raquo;</TD></TR><TR><TD CLASS="quote">dry ice</TD></TR></TABLE>
The only way he'd have anything black in his trunk on a '97 Civic and the material be stock is if the car is black and it's the sound deadening. I don't know why it'd be gooey and soft though.
Old Mar 5, 2008 | 02:16 AM
StorminMatt's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
The only way he'd have anything black in his trunk on a '97 Civic and the material be stock is if the car is black and it's the sound deadening. I don't know why it'd be gooey and soft though.</TD></TR></TABLE>
If someone had oil spill in the trunk, then the sound deadening material would become gooey and soft.
Old Mar 5, 2008 | 09:23 AM
NOFX's Avatar
H-T White Ops
Right now we're just theorizing. I'd like to see the photos.
Old Mar 5, 2008 | 02:39 PM
93whtlx's Avatar
Default Re: (StorminMatt)
Ill second the oil on the dedning pad. When I got mine. I found the bottle of oil with the hole in it below the spare. IT WAS A MESSSSSSSS. simple green and an sos pad worked pretty good.
Old Mar 5, 2008 | 02:43 PM
i was very busy today so i won't be getting any pictures tonight. i will try tomorrow
Old Mar 6, 2008 | 02:53 PM
Default Re: How do you clean dirty trunk?? (kcjohnnyboy)
Here are the pictures:
I think it is just the tar and I just need to remove it because this is just all messed up.
Old Mar 6, 2008 | 03:29 PM
stock ek's Avatar
that is sound deading my friend the best and quickest way is dry ice but if you want you can use a chisel hammer and wd40, trust me use the dry ice the chisel takes alot longer and is alot messier.
Old Mar 6, 2008 | 03:39 PM
JDM_SOHC's Avatar
Default Re: How do you clean dirty trunk?? (stock ek)
Sound Deadening Floor Hardener
Dynomat
Old Mar 6, 2008 | 04:27 PM
jdmej814's Avatar
Default Re: How do you clean dirty trunk?? (JDM_SOHC)
thats a good 20 bucks in there..hahaha!...i sued dry ice...use that.works!!! dont rush it either..
Old Mar 6, 2008 | 04:47 PM
yeah that was just half the change that was in there. the rest in there is all stuck to the sound deadening. dry ice here i come
Old Mar 6, 2008 | 04:55 PM
KDL323's Avatar
atleast youll be rich with all the money you get in there haha! good luck
Old Mar 6, 2008 | 05:01 PM
what kind of dynomat do you guys put in after you take the sound deadening out? are there different kinds?
Old Mar 8, 2008 | 05:26 PM
stock ek's Avatar
Default Re: (kcjohnnyboy)
i just left mine out it saved some weight, i think all in all with the back seat out and all the sound deading i would say i saved 30-45 pounds
Old Mar 8, 2008 | 05:50 PM
Your Name's Avatar
Default Re: (stock ek)
power wash.. if not that set it on fire
Old Mar 8, 2008 | 05:53 PM
You DEFINITELY had an oil spill in there at one point. You might find that if you scrape the stuff away with piece of plastic, it will come off quite easily around the areas where the oil spilled. The oil itself softens the material AND makes it separate from the metal. For the rest of it, you will need dry ice.
Old Mar 8, 2008 | 06:10 PM
mattyfo0z's Avatar
Default Re: (Your Name)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Your Name &raquo;</TD></TR><TR><TD CLASS="quote"> power wash.. if not that set it on fire</TD></TR></TABLE>
Lol what the [freak]? Hahahahaha.
Old Mar 9, 2008 | 11:33 PM
thanks for the advice. i will do it when i get some time from school
Old Mar 10, 2008 | 01:03 AM
The Si's Avatar
O dang.. must clean my trunk before it looks like this
93grayeg
Detailing
13
Sep 14, 2009 08:11 PM
DA9 Integra
Jun 10, 2008 08:41 PM
supertouch
Honda Civic (2001 - 2005)
Aug 20, 2007 09:52 PM
G2_Fella
Sep 13, 2006 06:31 PM
vtakk eg
Apr 10, 2005 07:51 AM
