2.0l attempt advise....lol
Old Mar 4, 2008 | 07:04 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default 2.0l attempt advise....lol
i just have afew quick questions before my brain fries becuase i have been searching a lot to night.
fully built gsr plat
ok
if i do 84mm bore with sleeves and ls crank and lets say 13:1 cp pistons
wat rods do i order say from eagle...ls ones or gsr ones? also what pistons will fit the rod option....im so lost on this part
heeeeelp
Old Mar 4, 2008 | 07:08 PM
BILLETGRIP's Avatar
Default Re: 2.0l attempt advise....lol (.doeboyfresh.)
LS rods, any aftermarket b series piston unless you want to get stock pistons machined for the clips.
Old Mar 4, 2008 | 07:24 PM
Default Re: 2.0l attempt advise....lol (BILLETGRIP)
thank you greatly mind is exploadin tonight......
plan is to tryin go through golden eagle or exospeed for bore and sleeve
they by pistons and rods separate and ls crank
Old Mar 4, 2008 | 09:11 PM
95 integra's Avatar
Even with most aftermarket companies, "LS/B20" pistons dont have the cast in passages for the oil squirters whereas the B16/GSR/Type Rs do. Basically they are all the same, but slightly different.
Just insane
Jun 25, 2012 07:28 PM
94civicgsr
Mar 6, 2011 08:00 PM
katanamast279
Mar 16, 2009 10:11 PM
jeremy.
23
Apr 27, 2005 02:20 PM
1.8T_EG
Mar 27, 2003 06:36 PM
