rewiring gsr altenator plug in a 2000 si
Old Mar 4, 2008 | 05:53 PM
jay-d-em's Avatar
Default rewiring gsr altenator plug in a 2000 si
I have a 2000 si and I am swapping in a 98 gsr motor. I am using my harness but the plug is different on the gsr altenator. does anybody know how to match the color on a si harness to a gsr plug cuz the wire colors are different.
Old Mar 4, 2008 | 06:10 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
i think the wires are the same im pretty sure they are
Old Mar 4, 2008 | 06:18 PM
jay-d-em's Avatar
Default Re: (99hondacura)
I will double check but I don't think they are. can I just put the plugs side by side and wire them up the way look on the si plug?
Old Mar 5, 2008 | 05:38 AM
jay-d-em's Avatar
Default Re: (jay-d-em)
the gsr plug wire colors are :white/yellow, solid blue, black / yellow, white/ blue
the plug wire colors on the 2000 si
harness are: black/yellow, white/ green,
white/ blue, white/ red.
Old Mar 10, 2008 | 07:47 AM
jay-d-em's Avatar
well I wired the plug. I dunno if I did it right I just match the wires from the si plug by putting them in the same location in the gsr plug. hope it works.
Old Mar 10, 2008 | 09:56 AM
drtysohc's Avatar
That probably isn't the greatest idea. Look at a wiring diagram and make sure everything is right.
Old Mar 10, 2008 | 10:58 AM
Blk00EJ8's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-d-em &raquo;</TD></TR><TR><TD CLASS="quote">well I wired the plug. I dunno if I did it right I just match the wires from the si plug by putting them in the same location in the gsr plug. hope it works.</TD></TR></TABLE>
Actually, that is right. You have 2 plugs, 8 pin and 2 pin, and then 1 plug with 10 pins but only 9 leads, no? Match them color for color and you will have an extra ground that is no longer necessary. You should be set.
Old Mar 10, 2008 | 12:36 PM
jay-d-em's Avatar
Default Re: Re: (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, that is right. You have 2 plugs, 8 pin and 2 pin, and then 1 plug with 10 pins but only 9 leads, no? Match them color for color and you will have an extra ground that is no longer necessary. You should be set.</TD></TR></TABLE>
Its the altenator plug I am converting which ony has 4 wires.
Old Mar 10, 2008 | 01:14 PM
Blk00EJ8's Avatar
Default Re:
Oops, on me
cranker
May 30, 2010 09:27 PM
FlewByU352
Mar 14, 2010 05:58 PM
blo2k1
Sep 5, 2004 08:05 PM
