launch control/ preload / clutch switch problem..
how can i use my clutch cut launch control and still preload a lil for slicks. soon as i let the clutch up a hair launch control kicks off cause the switch is being released? any ideas?
we have a special adjustable clutch switch that we use (not for lauch control, but can be used the same)
you just have to make a bracket to mount it.
another option is to put the arming switch on your e-brake.
most computers have lauch controll based off of VSS as well, thats obviously the easiest.
i suppose i could set it up to work on the ebrake pinswitch.. as long as i get the ebrake fully down before i have to shift it should work
anyone know what the blu/blk wire on the starter relay is ? just a ground when clutch is down or a power? just wondering. i may try to hook launch up to ebrake switch
wwolf771177
Dec 17, 2013 05:44 AM
fryman
Sep 28, 2011 05:47 AM
