92 gsr overheating....
Old Mar 4, 2008 | 04:42 PM
donnsterr's Avatar
Default 92 gsr overheating....
wudz good i got a overheating problem can sumone help me out.. ok its a fan thing i changed the fan switch and relay worked out for about a month then went out again..and i hooked up a fuse in the fan relay plug to keep the fan on while im driving.. now this worked out for about six month and went out on me..the fan works i directed to the battery and it ran so its not the fan motor....sooooo what is it??? can i please get sum help....
Old Mar 4, 2008 | 08:17 PM
GiT LaO'd's Avatar
Fan switch perhaps? I know my 1990 Doesn't come on, on its own because of the previous work done by the shop that did the swap for my buddy...
I rigged up a manual fan switch to my dash so I can turn on off as I please...
Old Mar 4, 2008 | 09:35 PM
stealth50k's Avatar
Might just be some crappy fuses that were used. check to see if your thermostat sensor is working. If that doesn't work then thats your culprit. Make sure the ground on the thermostat is connected also.
Old Mar 5, 2008 | 03:13 PM
donnsterr's Avatar
Default Re: 92 gsr overheating.... (donnsterr)
thanks for the info ill check um out
Si joey
Oct 21, 2015 09:39 PM
apexi_rsx
Jul 19, 2013 07:43 PM
19 crx 89
10
Aug 26, 2010 12:38 PM
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
turbo*s2k
Oct 27, 2003 06:33 PM
