What's the name for this?
Old Mar 4, 2008 | 02:35 PM
schumi's Avatar
Default What's the name for this?
The metal clamp which holds the fan was rubbing on these pipe and there is a crack on the pipe....See the photo and the markings in red.
What's this pipe called? Which is best place to get it? Is its easy to install?
IMG]http://i31.photobucket.com/albums/c389/juniorschumi/GC/IMG_0361.jpg[/IMG]
Old Mar 4, 2008 | 02:39 PM
VTEC_PRODUCTION's Avatar
Default Re: What's the name for this? (schumi)
number 1 you need to be clearer. number 2 that picture is horrible you need to make an arrow next time. 3 i will get back to you. ill check mines cuz your pic sucks...
Old Mar 4, 2008 | 02:58 PM
[ iLL ] iNt3GrA's Avatar
Default Re: What's the name for this? (VTEC_PRODUCTION)
is it running out of your A/C compressor? it looks like it is an A/C line if so you prob lost all the pressure in the line. If u change the pipe you will need to take it to a shop to have your A/C filled
Old Mar 4, 2008 | 03:58 PM
schumi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">number 1 you need to be clearer. number 2 that picture is horrible you need to make an arrow next time. 3 i will get back to you. ill check mines cuz your pic sucks...</TD></TR></TABLE>
AAgreed...its the top view. If its helps anyway, you can see the header pipes on top left corner, radiator plastic shroud
Old Mar 5, 2008 | 12:21 PM
vshavoc's Avatar
Its an ac line. I changed to a koyo radiator and the same thing happened. I didn't notice it was rubbing until it was too late. They want like 200 for a brand new one. I can't tell you if it's the return line or what because I never got it fixed and I just took the whole a/c off.
Old Mar 5, 2008 | 06:42 PM
schumi's Avatar
Default Re: What's the name for this? (vshavoc)
Same thing here...I put a koyo radiator and continued with the stock fans,...
$200 just for that damn pipe? anyone knows what is it called? thanks
Old Mar 5, 2008 | 10:35 PM
HONDACURA-DB8's Avatar
Discharge hose
Old Mar 18, 2008 | 03:26 PM
schumi's Avatar
Default Re: What's the name for this? (HONDACURA-DB8)
thanks.....Went to the dealer...its $237+ Tax.. ...
May be I should visit a junk yard to try my luck....
schumi
Feb 27, 2008 08:16 AM
poorman's type-r
Jul 8, 2007 08:44 PM
GeeGee
Welding / Fabrication
May 11, 2007 06:35 PM
BoostinEm1
Jan 5, 2006 10:34 AM
Aeka GSR
Jun 12, 2002 07:22 PM
