VTEC noise
Old Jul 6, 2002 | 11:01 PM
Ideal R's Avatar
New User
Default VTEC noise
If I drive my R to VTEC range (around 7000rpm), then let off the gas COMPLETElY, I heard a werid electronic noise under the hood. The noise goes away right after the rev drop under 5700rpm (out of VTEC). Anyone else have this "problem" or is it normal?
thanks in advance
Old Jul 6, 2002 | 11:53 PM
uNF$@#!'s Avatar
Default Re: VTEC noise (Ideal R)
im sorry you will have to be a little more clear than "strange electrical noise"... what does it sound like....electric grounding?
as always, i would be worried if i hear weird things nothing throwing CELs
[Modified by Soup ****, 3:53 AM 7/7/2002]
Old Jul 6, 2002 | 11:56 PM
GokuSSJ4's Avatar
Default Re: VTEC noise (Soup ****)
hmm! you have to be more clear about it...
Old Jul 7, 2002 | 12:36 AM
RagingAngel's Avatar
Default Re: VTEC noise (Spoon1)
My car falls outta VTEC with a pretty audible "click" .....
not sure if that is what you are referring to.....
Old Jul 7, 2002 | 08:08 AM
Ideal R's Avatar
New User
The noise is like continuous "gi......" sound, definitely not a single "click" noise.
I will try to record it and post it up.
The werid thing is if I let the engine free rev in neutral, that "gi..." sound won't present at all. But it is very noticeable when I am driving in gear dropping out in VTEC. Everything is fine if not in VTEC or if I drop out VTEC by upshifting. I start to wonder will the noise only present when the rev is dropping slowly (not much sense but...).
I might try to lift the throttle partially instead of fully to drop out from VTEC and see what happen.
Old Jul 7, 2002 | 10:07 AM
Stumpy's Avatar
I don't think VTEC engages in Neutral, someone please correct me if i'm wrong.
Old Jul 7, 2002 | 10:25 AM
Hard2Find's Avatar
Default Re: VTEC noise (Stumpy)
if you have VTEC controller, VTEC will engage in neutral. and i tihnk if your ECU is chipped also.
Cheap Bastard
Jun 25, 2006 05:08 PM
94LSVtecTeg
Aug 10, 2003 08:06 PM
typeee
Nov 28, 2002 07:44 PM
