one of the hundreths startup issues=(
Old Mar 4, 2008 | 12:11 PM
lilsol89's Avatar
Default one of the hundreths startup issues=(
okay...my car won't start.you may know that due to my topic title. well.when I attempt to start my 94' del sol.it will turn over.(doesn't sound weak).but won't fully start.and I need my car to go to class and work.oh boy.failing and getting fired is not the best thing in life right now.so any advice on what the problem could be or how/what I can do to revive my lil sol once again..thanks guys=D
p.s.
.just put in new spark plugs and freshly changed oil.
Old Mar 4, 2008 | 12:40 PM
crazyguy's Avatar
Default Re: one of the hundreths startup issues=( (lilsol89)
check your starter, and spark plug wires firing order
Old Mar 4, 2008 | 12:52 PM
lilsol89's Avatar
Default Re: one of the hundreths startup issues=( (crazyguy)
Aight.i'll check it out.thanks
Old Mar 4, 2008 | 12:54 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilsol89 &raquo;</TD></TR><TR><TD CLASS="quote">okay...my car won't start.you may know that due to my topic title. well.when I attempt to start my 94' del sol.it will turn over.(doesn't sound weak).but won't fully start.and I need my car to go to class and work.oh boy.failing and getting fired is not the best thing in life right now.so any advice on what the problem could be or how/what I can do to revive my lil sol once again..thanks guys=D
p.s.
.just put in new spark plugs and freshly changed oil. </TD></TR></TABLE>
Ditto on checking the firing order,
but if the firing order is right, put your old plugs back in, maybe you bought the wrong ones?
Old Mar 4, 2008 | 01:05 PM
lilsol89's Avatar
Default Re: one of the hundreths startup issues=( (Dasfinc)
put the old ones back in..k..i'll try that.but what if my old ones had like carbon residue??.should I still put them in??.
Robert Watson
Aug 9, 2017 09:23 PM
tambara
16
Apr 20, 2008 01:01 PM
em1_fox
Oct 28, 2007 12:11 PM
x3kevin
May 15, 2007 12:51 PM
project civic
Mar 10, 2005 08:35 AM
