1999 Civic D16y8 JRSC
I have a JRSC for a 88-90 Civic/CRX. I have read up on here that I MIGHT need a different intake manifold for the 1999 D16y8 head. Can anyone confirm this?
My other question is the supercharger pulley. On the 99 D16y8 is it a 4 rib or 3 rib pulley on the alternator or the crank pulley?
Thanks in advance
- I have searched and found limited information.
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsjeff »</TD></TR><TR><TD CLASS="quote">I have a JRSC for a 88-90 Civic/CRX. I have read up on here that I MIGHT need a different intake manifold for the 1999 D16y8 head. Can anyone confirm this?
Thanks in advance
- I have searched and found limited information. </TD></TR></TABLE>
JRSC REPLACED the intake manifold IIRC....
Thanks in advance
- I have searched and found limited information. </TD></TR></TABLE>JRSC REPLACED the intake manifold IIRC....
Thanks in advance
1. Yes you will need a different manifold. You can run a 99-00 manifold on an earlier motor if you plug the air injection holes, but not vice versa. Two words: vacuum leak.
2. As stated, I believe it's a 3-rib belt on the 3-rib blower pulley, 4-rib alt pulley, and 4 rib crank pulley. You have to make sure your pulley and belt alignment is sharp and the belt tension is sufficient. I had trouble with my JRSC before where the 3-rib belt would hop ribs on the 4-rib pulleys. Pretty annoying.
Thanks in advance
- I have searched and found limited information. </TD></TR></TABLE>1. Yes you will need a different manifold. You can run a 99-00 manifold on an earlier motor if you plug the air injection holes, but not vice versa. Two words: vacuum leak.
