Shift linkages in B swap
I'm swapping a B16 from a '94 Del Sol to a '93 coupe. Will the shift linkages swap easy? I heard that my original linkage from the D16 will not fit the B16 (makes sense) but the linkage from the Del Sol is too long for my coupe. Is this true?
shift linkage is easy to swap. but the bitch pin is really hard to get out all the time. u will need 99-00 honda civic si and 94 and up integra shiftlinkage. and no.your stock d series shift linkage wont work. and u will also reuse the motor mounts,axles from del sol or get new motor mounts. and whatever u need is depends on how complete the b16a swap is that u are getting. pm me if u have any problem
Modified by crazyguy at 11:36 AM 3/4/2008
Modified by crazyguy at 11:37 AM 3/4/2008
if its a whole swap all you'll need is shift linkage from a integra.
everything else will bolt right in.
if you can you may want to grab the radiator too, if its a dual core.
and no dseries linkage wont work.
turbodelsolb16a2
Jul 28, 2013 11:37 PM
jdm_eg
Oct 6, 2008 12:51 PM
dobbs1027
Sep 9, 2004 05:55 AM
