z6 build
Old Mar 4, 2008 | 07:57 AM
brocknroll's Avatar
Default z6 build
i have a stock z6 in my 92 hatch. with a leighweight flywheel and exhaust ,intake. im wanting to go boost but not sure what turbo and how much to push or would i be happier with a cam and valve upgrade on a stock bottom end.
Old Mar 4, 2008 | 08:00 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: z6 build (brocknroll)
I wold say go turbo and lurk around here for a while:
https://honda-tech.com/zeroforum/16
Probot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brocknroll &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock z6 in my 92 hatch. with a leighweight flywheel and exhaust ,intake. im wanting to go boost but not sure what turbo and how much to push or would i be happier with a cam and valve upgrade on a stock bottom end.</TD></TR></TABLE>
depends on your horsepower goals - a turbo setup on stock internals can land you around 220-240whp. with the money you spend upgrading the vavletrain..you'll wish you saved for a turbo setup or a swap.
Old Mar 4, 2008 | 08:10 AM
brocknroll's Avatar
how much i safe to push i have a converted p06 with a chipped revs to 7800 is that safe or should dwon it a little. i am also runnin a vx trans.90 in second 130+ in 3rd i was wantin to go to a dx trans which would be better or should i get a different one. any help on this would help
Old Mar 4, 2008 | 08:12 AM
justinCO's Avatar
Like said, depends on your power goals. It is fairly cheap to rebuild that old engine and boost it. That's what I would suggest, it also largely depends on your budget.
If you want any details or prices for rebuilding your motor let me know. I am going through said process right now on my D... (see sig).
Old Mar 4, 2008 | 08:18 AM
brocknroll's Avatar
i not looking for that much boost just want more power i would love to put down over 200 at hte wheels i just want somethin to beat most b series with a single cam lige the gsrs and maybe turbo b16.
what kind of rebuild should i go for it would be hard to do seein how its my onlt dd for now. the motor doesnt burn at all or leak .
Old Mar 4, 2008 | 08:39 AM
justinCO's Avatar
Default Re: (brocknroll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brocknroll &raquo;</TD></TR><TR><TD CLASS="quote">i not looking for that much boost just want more power i would love to put down over 200 at hte wheels i just want somethin to beat most b series with a single cam lige the gsrs and maybe turbo b16.
what kind of rebuild should i go for it would be hard to do seein how its my onlt dd for now. the motor doesnt burn at all or leak .</TD></TR></TABLE>
Well, you have lots of options just depends on how fast (ie: money you want to spend) you want to go.
If you just want a little more power, use your stock motor and piece together or buy an inexpensive turbo kit. You could probably get away with 6-8psi safely for quite a while, but not sure that will get you over 200whp. At any rate you should still be able to hang with or beat n/a b16/18's but not likely turbo charged ones.
If you want to rebuild you're looking at some down time. For a DD it's probably not ideal unless you build a motor on the side (that's what I'm doing).
Justin
Old Mar 4, 2008 | 10:03 AM
brocknroll's Avatar
ive heard that the z6 is the smartest d to boost. and it can handle 6-8 on stock internals. i would run 6 all day and be happy for now till i can build a bottom end for more. a buddy ran 8 on a 220k on it im not sure if it was a b7 or a shitty 8vlave but he ended uo blowing it in two days and on that and he was untuned as well. although he was runnina greddy emanage. im just trying to figure ou which route to go
Old Mar 4, 2008 | 10:07 AM
brocknroll's Avatar
i have a b7 block and crank lying at the house that i could build what would be best for that build
Old Mar 4, 2008 | 10:54 AM
justinCO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brocknroll &raquo;</TD></TR><TR><TD CLASS="quote">i have a b7 block and crank lying at the house that i could build what would be best for that build</TD></TR></TABLE>
b7? I am not sure...that is a d15 isn't it? I'd imagine you'd have to get a lot of new parts as the z6 parts might not be interchangable with the d15 (tranny, head, starter, alt, etc...)
Old Mar 4, 2008 | 11:15 AM
HMTforlife's Avatar
Default Re: (justinCO)
Cam and valve upgrade on your stock bottom end blows turbo out of the water
Old Mar 4, 2008 | 04:23 PM
brocknroll's Avatar
everything interchanges betwenn the two i switched over from my b7
Old Mar 4, 2008 | 04:36 PM
brocknroll's Avatar
seriuosly which would give me a good hp burst throughout low to high range rpm.
any ideas on q/t on 6psi and on built head
Old Mar 4, 2008 | 05:04 PM
1992Si's Avatar
Go check out http://www.turbod16.com all your answers are there.
What???
Don't bother with a built head for 6psi
Old Mar 4, 2008 | 06:16 PM
h22aBB4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinCO &raquo;</TD></TR><TR><TD CLASS="quote">
b7? I am not sure...that is a d15 isn't it? I'd imagine you'd have to get a lot of new parts as the z6 parts might not be interchangable with the d15 (tranny, head, starter, alt, etc...)</TD></TR></TABLE>
its the d15b7 out of a civic dx. the z6 parts are interchangable with it... its ob1 d series
as far as your build, the cheap way to build a bottom end is with vitara pistons (theyre 75.5mm bore and will lower your compression ratio), some h beam rods (tunertoy are cheap, eagle are good but more expensive), and acl bearings with it, then top it off with arp head studs and you're set.
ej2 coupe
14
Sep 16, 2008 08:18 PM
foowitdaredek
12
Apr 22, 2007 11:56 AM
yackkie_k
Mar 28, 2007 01:14 PM
92CHB
Oct 1, 2005 09:19 AM
-16V-
18
Dec 24, 2003 10:20 AM
