Axle seal question
Old Mar 4, 2008 | 07:46 AM
BiG Chris's Avatar
Default Axle seal question
Ok I searched before I posted this but with my swap I am using the halfshaft from a delsol along with the axles. The trans im using is a J1 and now the seal on the driver side is leaking on the trans. I found out that this halfshaft is smaller diameter than the DA halfshaft but my question is do I need to switch back to a DA halfshaft and axle or what seal do I need to get?
Thanks in advance
Old Mar 4, 2008 | 09:59 AM
jlicrx's Avatar
Default Re: Axle seal question (BiG Chris)
get seal for 94 and up Integra
Old Mar 4, 2008 | 10:15 AM
alscrx's Avatar
I didn't know you can use Del sol axles.....
Well if the halfshaft seal is leaking and the shaft is from a SOL then use the SOL seal
J1 passenger side seal is from a 90-93 LS though
Old Mar 4, 2008 | 10:19 AM
IT GUY's Avatar
Default Re: Axle seal question (alscrx)
http://www.sonshondaparts.com/...Irno=
Old Mar 4, 2008 | 12:11 PM
jlicrx's Avatar
Default Re: Axle seal question (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.sonshondaparts.com/...Irno=
#16 </TD></TR></TABLE>that is the passenger side seal - he needs driver's side which is different
Old Mar 4, 2008 | 12:12 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">J1 passenger side seal is from a 90-93 LS though </TD></TR></TABLE>only if using 90-93 Integra intermediate shaft
Old Mar 4, 2008 | 12:17 PM
BiG Chris's Avatar
I check the parts out and what I found out is that the seal thats in the tranny is Shaft Size=1.811" Housing Bore=2.697" Outer Diameter=2.705" Width=0.295" and the seal for a 94 up integra is Shaft Size=1.575" Housing Bore=2.205" Outer Diameter=2.213" Width=0.354" so the 94 up is smaller
Old Mar 4, 2008 | 12:20 PM
IT GUY's Avatar
Default Re: Axle seal question (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">that is the passenger side seal - he needs driver's side which is different</TD></TR></TABLE>
my bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">only if using 90-93 Integra intermediate shaft</TD></TR></TABLE>
why would the passenger side seal (like the one I posted by accident ) be dependant on the intermediate shaft? That axle has nothing to do with the intermediate shaft.
Old Mar 4, 2008 | 12:38 PM
jlicrx's Avatar
why would the passenger side seal (like the one I posted by accident ) be dependant on the intermediate shaft? That axle has nothing to do with the intermediate shaft.</TD></TR></TABLE>the passenger side isn't dependent on the intermediate shaft - you may have misread that - i was quoting the post by alscrx
edit: sorry - i misread his post - he said Passenger Side
Old Mar 4, 2008 | 02:08 PM
BiG Chris's Avatar
can anyone else chime in please
Old Mar 4, 2008 | 07:22 PM
BiG Chris's Avatar
Someone else?
Samuel6731
Mar 24, 2014 05:07 PM
92integracer
Dec 3, 2009 11:59 AM
SlammedEG6
Suspension & Brakes
Aug 29, 2008 03:14 AM
chris5n6
Mar 21, 2002 06:08 AM
