Broken Rear LCA Bolt
1994 Acura Integra LS
problem: The OUTTER LCA Bolt snapped on the head side and it broke off on the side where the nut is..
The nut is still in tact so im not sure if part of the hub is broken or what..
what i need to know is if i need to replace my hub along with the bushing and bolt or if i just need to replace the bushing and bolt.
i believe it broke the metal in the trailing arm that the bolt was holding..
Modified by integra_si-vtec at 10:36 AM 3/4/2008
