B18C GSR into EF- What parts?
Old Mar 3, 2008 | 09:28 PM
vtec93accord's Avatar
Default B18C GSR into EF- What parts?
I have a B18C GSR with LSD Hydraulic Tranny. I know i need the following:
Rywire harness for B18C
Mount kit for hydraulic trans in ef
90-93 DA axles
Shift linkage for b series in an ef
ECU of choice-OBD1
Im unsure about the following:
Upper and Lower radiator hoses
Will fuel feed line on my hatch be long enough?
I have enough vacuum line
Rear mount bracket
Was told i can use the GSR intermediate shaft?
Throttle cable problem with OEM GSR intake manifold- What to do to make it work?
Civic clutch cable, will it work well with the innovative kit?
If im missing anything please lemme know as i am trying to do this with my car being down for a day or two instead of weeks haha. Its a 91 DX Civic hatch that its going into if that helps any. I also know the shock tower will need to be beat in as well, just where at exactly? And i know the crossmember will need to be modified as well. Please help!!!! Thanks.
Old Mar 4, 2008 | 04:35 AM
CRX Toad's Avatar
Default Re: B18C GSR into EF- What parts? (vtec93accord)
https://honda-tech.com/zerothread/1508680
Old Dec 24, 2008 | 08:45 PM
DCFerris's Avatar
i'll make it real easy for you
http://www.norcalcrx.org/library/b18cswap.shtml
QuarterMileMaster
12
Apr 22, 2007 08:29 AM
Obese
Apr 30, 2004 07:40 PM
EG*MonKEY
Mar 29, 2004 05:35 PM
gen2spoon
Nov 28, 2003 08:45 AM
